I had been having issues on ADE on ebooks from my library that had been on hold & when ready I plugged the nook into the computer & downloaded the when I was on ADE - one worked yesterday & the 2 this morning are giving me(on my nook when I click on the book) a Error message saying item has been returned. I looked a few links & see that the older version of ADE works better on older nooks(mine is older a simple touch) should I uninstall ADE in the control panel then download it again and if I do this how can I get the older version? this morning I did erase authorization & then authorize(did not help)-I have tried this on google chrome & internet explorer. IF I UNINSTALL ADE & then download it again CAN I STILL USE MY SAME EMAIL ADDRESS & PASSWORD I AM USING ON ADOBE DIGITAL EDITIONS?
The older version can found on this link: Adobe Digital Editions downloads
will uninstalling the ADE I have now(editions 4.5) and downloading the
older version of Adobe Digital Editions help with this issue? If I install
the older version can I use the password I have now for Adobe Digital
Editions or will I need a new one. IF this does not work - should I
uninstall the older version & get the latest edition of ADE. If I
uninstall ADE will the library ebooks I have on there remain?
You can used the same Adobe ID and Passwort.
The eBook should found under My Digital Edition under your My Documents Folder.
do I need to erase authorization before I go to uninstall Authorization in
Adobe Digital Editions?(on each computer)
No its not needfully.
I downloaded the old version of ADE & then tried to get a ebook from the
library & I get a pop up message - ERROR-CHECK ACTIVATION? so I went back
and downloaded the new version of ADE & that seems to work(for now - I will
be able to see better when I have my next book on the waiting list showing
available) I have 1 more question-sometimes I finish a book then I plug my
Nook into the computer and click on-RETURN ITEM then I click on REMOVE FROM
LIBRARY and it still shows in adobe digital editions and on my computer
Good Luck.
well this helped a bit(the old version of ADE is on one computer & it
worked - I di have to uninstall ADE on another computer because it would
not work & I even went into the control panel(default/associate a file
type) & tried to click on .acsm to get library books to download in ADE -
did not work but in the future I might try again to add ADE(old version) to
another device & try again
