I'm having the same issue as posted in some of the other topics but the fixes aren't working. I started a chat with Adobe and they couldn't help me- they said post here.
Activation error Adept Request Expired- when I try to authorize ADE.
- I'm using Windows 8.1. and my time zones are fine.
- My Adobe login and password are fine.
- I tried the ADE 4.5, which didn't work so I went back to 3.0, hoping that would be the fix, still got the error.
I tried the whole:
"Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK."
I still get the error. I can't de-authorize my program because it's not authorized in the first place. Ctrl, shift D does nothing.
Is there anyway to get this working? It works fine on my old XP laptop, go figure.
Have you check the time, date and the timezone of your System?
Have you remove the key with a user with admin rights?
Yes I only have one user on my laptop- me. I'm the admin.
Thank you, it was a timezone issue, after all. My clock looked proper etc. but I had to adjust the timezone and then manually change to the time to reflect the proper time. Thank you!
You are welcome.
