Hover blocks out the link
Jul 20, 2016 Jul 20, 2016
When I hover over links they're getting blocked out.
622
?version of RH? Output being created?
RH2015 12.0.1.338
WebHelp
?Happening on all browsers or just one? Does it happen with the sample projects included in RH?
Tested on Chrome and Firefox. Results the same. Where do I find the sample projects?
?They should be appearing on the Starter pane when you fire up RH - but you can also find them in your "My RH Projects" folder too. Did this effect just start happening or has it always been busted for you in RH2015? You might also want to run the patches (I think we're up to 3 or so now) & regenerate your help content again.
I just took over this project. The previous version was done 2 years ago and works fine. This is the first version generated with RH2015.
Temporarily link a topic to a different CSS and see if that fixes this
problem. If it does, the issue is within your CSS.
Been awhile since I've used RH, Peter.  How to I link a topic to a different CSS?
On the Project tab, clicked Settings. The CSS for Style Mapping was set to the wrong CSS (RHStyleMapping.css). Changed to the correct css and regenerated. Same problem.
Here's how the Settings popup looks. Do I need to update these fields?
That dialog box only affects documents imported from Word or Framemaker.
The stylesheet may be set in one or more of the following places:
  1. in a master page
  2. in a topic
  3. in the single source layout.
The quickest way to change the stylesheet for your whole project is to set the stylesheet in the single source layout. This will overrule any stylesheets applied on a master page or on a topic.
  1. Open the Single Source Layouts pod.
  2. Right-click on your SSL and select Properties.
  3. Expand Content Categories.
  4. Click on each category (there may be only one), tick Apply to all Topics, select the CSS option and select the stylesheet you want to use.
Recompile and see if the changed stylesheet corrects the issue.
If not, you will need to check how your links are configured. It's possible style applied to the blocked out links have the Pseudo class "Hover" set to with a background (highlight) colour that matches your link colour.
Hi there
The video below talks about the CSS in the output settings. Maybe it will help?
Click here to view
Cheers... Rick
And here's another video that may be useful as well.
Click here to view
Cheers... Rick
Jul 21, 2016 Jul 21, 2016
Watched the videos. Didn't help.
Found the following when I select Text-only popup hotspot instead of Hyperlink. Looks like the problem. If it is, we have another problem.The system doesn't save any changes I make to the Pseudo class settings. I've also tried editing the CSS file directly and it reverts back when I generate the file. If I can remove the highlight color, I think this problem goes away. Why aren't my settings saved?
Where is it?
Did you watch either of the videos? Or is that question directed to Amber?
Doing it now
Houston, we have liftoff. It appears the previous tech writer had the same problem. I went into an older version of the help system and found a CSS with the same name only it had an "x" after it. Took a look and it didn't have the highlights the current version has (see graphic above). Imported, applied to all topics and all is good.
Sorry to put you all through this when the solution was as simple as digging around for an alternate CSS. Thank you for your time and assistance.
Here's something else. The links that are being "blocked" are set to "Display in auto-sizing popup". The links on that page display normally. I changed the original link to "Display in frame" and regenerated. Now the links on the subsequent page are also being "blocked".
Jeff,
No, the samples work fine.
RoboHelp Documentation
Download Adobe RoboHelp
