I am having trouble inserting a PDF in to a word document. When I do it gives me the error of “There was an error opening this document. This file cannot be found.” Then after I hit OK a few times a message says “The program used to create this object is AcroExch. That program is either not installed on your computer or it is not responding. To edit this object, install AcroExch or ensure that any dialog boxes in AcroExch are closed.”
The version of windows I have is windows 7, 64 bit, Word 2013, and Adobe Acrobat X pro
Inserting object in Ms word is just to get the link of the the object. When you double click on it it will open up in difference windows (e.g., If we are inserting PDF as an object then the first page will inserted and when we double click on that page, the document will open as a pdf file in pdf software). So, inserting as an object is not editable in ms word itself.
If you want to insert all the pages of PDF document then follow the steps:
Hi travisdg22,
Please perform the following steps:
1-Open Acrobat>navigate to Edit>Preferences>General>Select Default PDF Handler>select Adobe Product:Adobe Reader X>Apply.
2 -If step 1 doesn't fix the issue, try to disable Protected Mode,Open Acrobat.Edit>Preferences>Security(Enhanced)>Protected View>Off>OK
Let us know about the results.
Thank You!
Shivam
This method does work, as I can now get the first page of the PDF into word. But I have a several multi page PDF's I would like to combine into my word document. I looked online and it seems the only way to insert a multi-page PDF is to break up the PDF in several one page PDF's and insert them in one by one. This is not feasible for what I am doing. Is there any (less tedious) way to insert a multi-page PDF into a word doc?
Thanks Travis
In Ms Word
Open the Word document and insert the images into the document as you normally would.
a. Click on Insert Tab and choose Images
b. In the dialog box browse your folder that you have created (Images)
c. Select all your desire images and Click Insert.
Bless you! This is such a simple and easy fix. When you convert to JPEG or PNG it automatically breaks the multiple page pdf file up into multiple images.
Thank you so much for this instructions, you saved me!
Hi Travisdg22,
Your suggestion worked without any issue. Thank you so much!
I'm having trouble inserting pdf doc into Word doc. I think I used your advice above many years ago but now the latest Acrobat is different. Can you help again, please.
Have you try this...
Click on Insert Tab and find "Object" and from drown menu choose Objects.
2. Click on Create from file Tab and click on Browse button (browse your pdf file) and click OK (if you want to Link with your file, check the Link to file box.
Let us know what are you doing with screenshot.
And Try to disable Protected Mode in Adobe Reader X or XI
Adobe Reader X
1. Open Adobe Reader X
2. From Edit menu select Preferences, Preferences dialog box appears.
3. Select General category on the list, uncheck or remove tick mark for "Enable protect mode at startup"
Adobe Reader's Protected Mode will be turned off
Adobe Reader XI
1. Open Adobe Reader XI
3. Select Security (enhanced) category on the list, uncheck or remove tick mark for "Enable protect mode at startup"
thanks
Great! we got it to work.
Thanks! Travis
Hahahah Problem was solved but mark correction answer to the owner... great good job @Tariq Dar
Thank you Travis. Very helpful
