Hello,
I try to install the new version of Creative Cloud for desktop (march 19, 2014), but it doesn't work.
I have W7, 64bits, 4 Go, french edition. CC for desktop is also in french.
I also have some trouble with the Premiere Pro, it's why i uninstall every Adobe CC applications and i try to reinstall them now.
I have the message :
Creative Cloud for desktop installation - error code : 50
Help me !
Valéry
Hi valParis,
Welcome to Adobe Forums
You can follow the below mentioned link -
http://forums.adobe.com/message/6227314
Let us know if that helps!
Garima
OK IT WORKS !!!
Follow the steps : http://helpx.adobe.com/creative-cloud/kb/failed-install-creative-cloud-desktop.html
To inform you, I check the PDApp.log as its told in the message :
The last lines are interesting, they tell that
1) Failed to create backup folder C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC
2) It was just after the success of insertAppletRelInfoList installation !
Here is the extract :
03/21/14 17:14:42:363 | [INFO] | | ASU | PIM | PIM | | | 1840 | SUCCESS insertAppletRegInfoList.
03/21/14 17:14:42:363 | [INFO] | | ASU | PIM | PIM | | | 1840 | SUCCESS insertAppletRelInfoList.
03/21/14 17:14:42:363 | [ERROR] | | ASU | PIM | PIM | | | 1840 | Failed to create backup folder.
03/21/14 17:14:42:378 | [FATAL] | | ASU | PIM | PIM | | | 1840 | Failed to create backup folder C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC
03/21/14 17:14:42:472 | [FATAL] | | ASU | PIM | PIM | | | 1840 | package installation failed and the return code was 50
03/21/14 17:14:42:472 | [ERROR] | | ASU | PIM | PIM | | | 1840 | Failed to install with return code: 50
03/21/14 17:14:42:566 | [INFO] | | ASU | PIM | PIM | | | 1840 | Successfully deleted temp guid directory
Hi - I only recently upgraded to Creative Cloud (2014 version) in early 2015. After encountering the 'error code 50' issue, I searched the Adobe support forums for a solution. I tried the uninstall/reinstall, running the cleaner, etc. Nothing worked.
After trying many other things, I decided to close Chrome while the installation process was running. I received no error message. During an upgrade recently (to CC 2015), I encountered the same 'error code 50' issue. I shut down Chrome, and the error disappeared.
I also had this problem. Tried everything they told me to do but nothing worked...
at least I had to reset my computer and now it works...
In my experience, almost every Creative Cloud installation error is caused by the acrotray.exe process that is running in the background.
You can attempt the numerous steps provided by the links above (which involve uninstalling CC, cleaning, reinstalling, etc.), or you can simply kill acrotray.exe process via the Task Manager on Windows, and attempt installation or update of Creative Cloud again.
This does it for me almost every time.
I simply attempted the install again and it worked.
"In my experience, almost every Creative Cloud installation error is caused by the acrotray.exe process that is running in the background.
This does it for me almost every time." Andrei I Gere
The best solution, thanks very much.
Just delete all the adobe's directories:
and
C:\Program Files\Common Files\Adobe
thanks, this helped!
Thanks JeffersonDias!
That did the trick, but it's sufficient to delete the following folder:
C:\Program Files (x86)\Common Files\Adobe\backup
...and all the other backup-folders you may find..
Took me one hour, Adobe, i want my money back!
my case here:
1. install, and error msg "error code A12E1".
2. close window firewall, install again, msg "error code 50".
3. follow the webpage step 1-4 :
http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
>>>( no need uninstall adobe software)
>>>( backup folder "\Users\AppData\")
4. Restart the computer, close firewall, install and msg "error code 50" again.
5. final try and it works
5a. right click (run as "admin") CC Cleaner Tool ("AdobeCreativeCloudCleanerTool.exe")
5b. follow the webpage "Solution 2: Run the CC Cleaner tool" :
>>>( Rename the following "OOBE" folders to "OOBE.old" : )
>>>( "\Program Files (x86)\Common Files\Adobe\OOBE" )
>>>( "\Users\AppData\Local\Adobe\OOBE" )
5c. Restart the computer, close firewall, install (run as "admin") and it works.
I had this problem for the last few days and today I tried it again and still got error 50. A friend of mine told me to log into adobe in my browser and then try it again. It didn't make sense to me but I trust him. So I went into my account, I checked my billing info just to make sure that wasn't the problem. Everything looked ok so I left the browser window open and tried updating CC again and it worked! I'm baffled and I thought it was a troll but it worked. Can anyone explain this to me?
I tried all of the above, then tried logging into my account as suggested by adlopez210 and it worked (THANK YOU!)
Am I alone in thinking that this has been an issue for well over a year, and the idea of having to jump through all these hoops to get the software to work is obscene? Come on Adobe, get your ____ together & make the software work!
I went to task manager and cleared out the adobe processes and background processes - specifically Adobe Update Service and then launch the cloud again and it worked
Please try the following
open a command window by going to
Start
and writing CMD press enter
the command window black with wite letters blinking shoud open
write the following
net user administrator /active:yes
close your user and you will find the Administrator user in the log in page
enter as administrator and install the creative cloud
exit the administrator user and in your normal user
open again the Command window
and write
net user administrator /active:no
to de activate the admin account
Hi all,
when i am trying to install adobe cc.iam getting an error message
"installation failed. please refer PDApp.log for more information.click here for help"
Please help me. iam using windows 10 OS
Sobin Mathew
