I have purchased books from Mills and Boon and tried to copy them to my Kobo ereader. However I keep getting an error message CE_copy_not_allowed_no permission to copy book.
Has you Digital Edition and your Reader authorize with the same Adobe ID?
I am not sure. I have three ereaders which do have some of the Mills and Boons books on them so I guess they are.
Then you should check it. In Digital Edition you can found the info under help > authorize info. In your reader can not say exaclty for this should check the helps of the readers.
Hi Nanaky
I didn't have my ereaders with me yesterday so I have brought them in today to check them. However I have checked the Digital Editions website and there is no help menu and when I search authorize info nothing comes up. Can you help?
Do are used with operating system?
I am using Windows 7.
Then start Digital Edition on your Windows. If the program are open check the menü for help.
Sorry I got confused I was going on to the website and not into Digital
Editions on my computer. I went into Digital Editions - Authorize
information and this was there.
connie67@iprimus.com.au | Adobe ID
(urn:uuid:6884d9eb-d834-49af-a3a8-08edb83dd79a). I couldn't remember my
password so I clicked on forgot password and changed the password and then
it wouldn't let me log in again I got the message You can only authorize
this computer with an Adobe ID that hasn't been previously used to
authorize any other computer or mobile devices. Please try again. Is
there any way to reset the authorization.
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Hello. I tried to complete the above but could only find
HKEY_CURRENT_USER - there was no adept key. Is there anything else I can
do?
If you click on HKEY_CURRENT_USER you can found the folder Software....then click on this and choose the next...Good Luck
Hello. This time I found adept but couldn't find export. Attached is the list that comes up.
Sent from my Samsung GALAXY S5
Also not under File > Export?
Hi Nanaky
I managed to authorise the computer. However I still cannot transfer books
to my ereader.
You can open the file in Digital Edition now?
I can open Digital Editions but still get the error message
CE_copy_not_allowed_no permission to copy book whenever I try to transfer a
book to my ereader.
Right click on the File in Digital Edition and choose Mediainfo.
I can open Digital Editions but still get the error message.
book to my ereader.
Has you check the Mediainfo?
I cannot find mediainfo. The closest thing in my digital editions is item
info and that tells me that "The document is licensed for a different user
account."
Then the eBook is not authoirze with your Adobe ID. So the its so it is no wonder that the copy does not work. You must used the same adobe id used which has used by the first open of the file.
Thanks Nanaky. I have now got it working for older books. Can you tell me
what this means please:
Error getting License Service: Communication problem:
E_LIC_ ALREADY_ FULFILLED_ BY_ ANOTHER_ USER
I tried to download some books I have just purchased and got the above
message.
Its mean that the eBook linked with the other authorize. Has you open the eBook with empty or other authorize before its work fine with the right authoirze?
Okay. I will try that. Thank you so much for all of your help.
Kind Regards
Connie
