10 Replies Latest reply on Jul 28, 2016 1:29 PM by dsackett
    testing for special characters? (JS Win CS5.5)
    dsackett
      Is there some sort of boolean or function to tell if a character is a member of the group of SpecialCharacters?
      I need to test whether a range of text ends in a carriage return & had used a loop that tested the last character of found items with myFoundItems[i].characters[-1].contents.charCodeAt() == 13, which was all well and good except when the last character happens to be a special character. Since special characters don't properly return a character code, the script errors out. I saw useful posts on filtering out & translating special characters to unicode, but nothing on a straightforward test.
      Maybe I'm still a rube enough to miss it in Jongware's reference...my skills are such that it looks like I'd need to identify and test all possibilities (ugh!). Seems like it'd come up enough that someone might have a handy function laying around...
      Thanks for any wisdom on this point.
        • 1. Re: testing for special characters? (JS Win CS5.5)
          dsackett Level 1
          I found a test, but I'd like to know if it is ill-advised. Evaluating the .valueOf a special character returns a 10 digit number, so this code just makes the number a string & checks the length. Since normal text & lower-order ASCII, like tabs or returns, are single character strings, they evaluate as a length of 1.
          for (i=myFoundItems.length-1; i>-1; i-- ) {
            if ((myFoundItems[i].characters[-1].contents.valueOf() + "").length < 10) {
              if (myFoundItems[i].characters[-1].contents.charCodeAt() == 13) {
                    // now safely determined this character's a return...
          • 2. Re: testing for special characters? (JS Win CS5.5)
            Marc Autret Level 5
            1. To check whether myChar.contents is a SpecialCharacters item, I think you can simply use the test
            ( 'object' == typeof myChar.contents )
            since in any other case typeof will return 'string' (assuming myChar is a valid Character instance.)
            2. Anyway, you can always and safely convert a single Character (or any Text) into a pure JS string using
            myChar.texts[0].contents
            This trick prevents the contents property from returning a SpecialCharacters item even if myChar is a 'special character.'
            More on InDesign special characters and Unicode issues:
            Indiscripts :: InDesign CS4/CS5 Special Characters [Update]
            Marc
            • 3. Re: testing for special characters? (JS Win CS5.5)
              Marc Autret Level 5
              Oops!
              In CS5.5 CS4 the SpecialCharacters enumeration wasn't coercing items into objects yet. Numbers were used instead.
              So in your case the test looks like
              ( 'number' == typeof myChar.contents )
              But I guess the texts[0] trick was already valid.
              Marc
              [Edited, thanks to Uwe Laubender]
              • 4. Re: testing for special characters? (JS Win CS5.5)
                Laubender Adobe Community Professional & MVP
                dsackett,
                do you want to detect this kind of special characters?
                Adobe InDesign CS5 (7.0) Object Model JS: SpecialCharacters
                ( There could be others as well. )
                Hi Marc,
                I just tested with my InDesign CS5.5 on Mac OSX 10.7.5.
                var doc = app.documents[0];
                var textFrame = doc.textFrames.add({geometricBounds : [0,0,"100mm","100mm"] , contents : "\n"});
                textFrame.characters[0].contents
                // Result: FORCED_LINE_BREAK
                Best,
                Uwe
                • 5. Re: testing for special characters? (JS Win CS5.5)
                  And we can take that a bit further:
                  var result = textFrame.characters[0].contents;
                  result.constructor.name
                  // Result: Enumerator
                  Uwe
                  • 6. Re: testing for special characters? (JS Win CS5.5)
                    Marc Autret Level 5
                    Thanks Uwe,
                    So my 'Oops' was wrong   [Should we cancel a 'oops' using !oops?]
                    Indeed I had lost the history of InDesign's Enumeration/Enumerator paradigm, which has been introduced in CS5, so the thing is already available in CS5.5 and my original reply should be correct.
                    And yet we already discussed that specific question here:
                    Re: Search document for SpecialCharacters Enumerator
                    Marc
                    • 7. Re: testing for special characters? (JS Win CS5.5)
                      Yes, we already discussed that. And with a reason.
                      The results for .contents can be a bit "ambiguous". It depends how and what exactly we ask.
                      See the following example from InDesign CS5.5 on Mac OSX where a text frame of a threaded story is selected. One footnote involved, a quarter space, one column break and a frame break:
                      Tested with code below. Results are documented with $.writeln() .
                      // Text or text frame selected
                      var story = app.selection[0].parentStory;
                      // Note: texts[0] is used:
                      var characters = story.texts[0].characters.everyItem().getElements();
                      var length = characters.length;
                      var constructorName = "Enumerator";
                      for(var n=0;n<length;n++)
                          var character = characters[n];
                          if(character.contents.constructor.name == constructorName)
                              $.writeln
                                  n
                                  +"\t"+
                                  /* Example result: 1399221837 */
                                  character.contents
                                  +"\t"+
                                  /* Example result: Enumerator */
                                  +"\t"+
                                  /* Example result: FOOTNOTE_SYMBOL */
                                  character.contents.toString()
                      Results in the JavaScript Console of the ESTK:
                      427    1399221837    Enumerator    FOOTNOTE_SYMBOL
                      476    1397847379    Enumerator    QUARTER_SPACE
                      514    1396927554    Enumerator    COLUMN_BREAK
                      822    1397125698    Enumerator    FRAME_BREAK
                      This time the value of contents is of type Enumerator, but is delivering "numbers".
                      I had to use the toString() method to get to the "names" of the enumerators.
                      It could be well, that $.writeln() does its part on this kind of presentation.
                      Uwe
                      • 8. Re: testing for special characters? (JS Win CS5.5)
                        Marc Autret Level 5
                        Hi Uwe,
                        Weird, isn't it? But there are good reasons that explain all you've seen.
                        1. First, the texts[0] trick does work only if you use it just before calling the contents property. In your example, the line
                        returns an array of Character instances, whatever the fact that texts[0] is used upstream. Then
                          characters[n].contents
                        will still return an Enumerator instance (assuming we are on a special character.) Your texts[0] has no effect because a Character specifier—…characters.everyItem()—has translated back your stuff into pure Character objects.
                        But if you change your line
                        into
                          var character = characters[n].texts[0];
                        then the trick will work again, .contents will return strings and the Enumerator issue will vanish.
                        2. Now, about the fact that the term "blabla" + myEnumerator returns a string based on myEnumerator.valueOf(), i.e. the underlying Number, instead of using myEnumerator.toString(), i.e. the underlying String, this is not connected to the fact that you are using $.writeln(). No, that's a generic BUG of the Enumerator object, which hasn't been implemented with respect to ECMA's specification regarding type conversion.
                        Normally, given an Object myObj and a literal string "blabla", the string concatenation "blabla" + myObj should implicitly invoke myObj.toString() in order to achieve the proper type conversion before concatenation. By the way in JavaScript we often use the syntax ""+myObj as a shortcut of myObj.toString(). That's a quick way of extracting the string representation of an object.
                        But, the Enumerator type doesn't follow this rule. I suspect that the + operator hasn't been fully and properly implemented. Used as an unary operator (+myEnumeror) we get a Number, as required. Indeed, +myObj is usually a shorcut of myObj.valueOf(), where the valueOf method is supposed to return a Number. But, regarding the term anything + myObj, the JS interpreter must select either an addition in case anything is a Number (and then myObj.valueOf() is the right guy), or a concatenation (in case anything is a String, and then myObj.toString() should be invoked.)
                        Problem with ExtendScript is that +myEnumerator means myEnumerator.valueOf(), which is fine, but that myString+myEnumerator is wrongly interpreted myString + myEnumerator.valueOf(), which finally leads to the string concatenation
                          myString + (myEnumerator.valueOf()).toString()
                        instead of
                          myString + myEnumerator.toString()
                        That's why we get the following (and surprising) result:
                        var specialChar = SpecialCharacters.BULLET_CHARACTER;
                        alert( specialChar.__class__ );    // => Enumerator
                        alert( specialChar );              // => BULLET_CHARACTER
                        alert( '' + specialChar );         // => 1396862068
                        Line #5 is OK. Since alert() expects a string, specialChar.toString() is implicitly invoked.
                        But Line #7 is a bug, as explained above.
                        Marc
                        • 9. Re: testing for special characters? (JS Win CS5.5)
                          Wow. Great explanation, Marc!
                          Thank you very much.
                          Uwe
                          • 10. Re: testing for special characters? (JS Win CS5.5)
                            dsackett Level 1
                            Marc & Uwe,
                            Wow--what a fascinating and edifying discussion--thank you so much!
                            I am putting the myChar.texts[0].contents trick to use. What I came up with worked OK, but it's most like the #7 emptystring + specialChar example above. Given that is a bug, how ID's Javascript interpreter handles it could change, so is probably not the best basis for code that could have a life beyond our current version. You probably averted some hair-pulling bug in the future. Thanks again.
