Graphic callouts imported as separate files
Jul 26, 2016 Jul 26, 2016
Hi, all.
I have imported a word document into RH11 in win7 environment. In Word, the document creator used the Word graphics tools to put outlines around graphic elements of particular interest.
When I import the Word document, those outlines are imported as separate graphics files and I can't simply drag them into place. Is there a way to get RoboHelp to import the graphic in one piece?
Thanks.
343
?I think you need to "flatten" the image so that all the bits are considered all one part of the image. Not sure how you tell Word to do that - maybe use another graphic tool?
?Quick Google reveals that you need to group all the objects that make up the image & then paste special to a new doc to get just 1 image.
Hi, Jeff. Thanks for that info. Unfortunately, Word will not let me select the figure and the outlines on top of it. I've gone through every option here:
Select a shape or other object - Office Support
--Nancy
Hi there
Personally, I'd use a screen capture utility to capture the image as it appears in Word. Then insert that captured image into the topic.
Or, if you are linking the Word document, remove all the separate images and replace it with the captured equivalent.
Cheers... Rick
Hi, Rick.
Yeah, I know I can redo it manually, just hoping I don't have to.
Dec 21, 2016 Dec 21, 2016
Hi Nancy,
I have the same problem when I import Word document with complex images into RH.
Here is my workaround:
In Word,
- I create a drawing area
- I import screenshots into this drawing area and I add any other needed drawing objects (captions, text, lines, etc.)
-  I copy my drawing area
- Special Paste / Image (improved metafile)
Doing so, you don't need any external capture tool
RoboHelp Documentation
Download Adobe RoboHelp
