      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Extra space between pages in document
Jul 26, 2016 Jul 26, 2016
I have a 146-page document in InDesign (facing pages), and there is a large gap in two instances between the spreads  -- one gap larger than the other. I'm using current version of INDD on a Mac. I have to create a combined page PDF for client of all pages and don't know if this will carry over to the pdf made from these pages in INDD.
I'm sure I inadvertently did this but I don't know what I did. All of sudden, this space.
Thanks for your help!
Jackie
29.0K
Community Beginner , Jan 18, 2021 Jan 18, 2021
I fixed this by doing the following:
  1. Go to the pages panel and highlight the spread in front of the gap
  2. Insert two pages immediately after the spread in front of the gap: the spread should appear immediately after the gap
  3. Select all from the spread in front of the gap and paste in place on the new spread
  4. Delete the original spread in front of the gap
Has something to do with an object being dragged to close to the edge of the pasteboard between spreads - but it can't be selected/deleted from either
that is usually the result of something at the edge of the pasteboard. It should not carry over, but if you want it gone, drag around all the content of the two pages on the spread and copy.
Delete the two pages, and add two new pages. Then paste in place to put your content back.
Participant ,
Jan 22, 2017 Jan 22, 2017
Thank you! this has been an issue on and off for a year now. So nice to have it solved.
Participant ,
I guess it occurred for me when I was dragging an article out of a library. I pulled it right onto the page but somehow it ended up right on the edge of a long, long bottom gap.
Jun 19, 2019 Jun 19, 2019
Nailed it! I had a rogue logo going off the pasteboard. Thanks.
Hi Jackie,
I'm guessing here as to what's happening. Can we see a screenshot of one of the spreads with a gap?
Did you start this layout using an earlier version of InDesign?
If so, it's possible that you unintentionally moved pages with the Page tool (Shift + P).
Select the Page tool and click on a Page that is out of position. Drag it toward the other half of the spread until the pages snap together.
Hope this helps!
Jeff
Very likely caused by Page Tool because I kept getting it when reaching for Black Arrow. This i screenshot.Screenshot 2016-07-26 13.18.45.png
I can't tell much from the Screenshot. Zoomed out too far.
Did you try moving the out-of-position pages with the Page tool?
Apr 10, 2017 Apr 10, 2017
Looks like zooming out too far actually helped resolve the issue.
Sorry, maybe this one will be more helpful.
Tried grabbing and moving upward but it snapped back as it is. Grabbed each page individually. Not sure how to do them together with Page tool. It is a facing page doc as is probably evident.
You have something trapped right on the edge of the pasteboard at the bottom on the right hand side. Usually copying and pasting  large items or multiple items larger than you document size this can happen. Delete this and the pasteboard will snap back. This can happen with guides too.
Sorry, grabbed one. Here is closer view screenshot.Screenshot 2016-07-26 13.54.14.png
I'm wrong about the Page tool.
Are you talking about the space between spreads vertically.
It's possible your document is getting corrupted.
Go to File > Save As and choose IDML as the format.
Reopen the IDML in InDesign and see if that helps! This will usually fix corrupted documents.
Susan seems to be right! [again!]
I can do worse!    ā€¦ I've never said it's why the op has a problem! I've just replicated it!
Susan would be SJ Riegel? Meaning the prob is stuff on the edges of the pasteboard? Which there is.
Happier thought than corruption anyways, but good to know what to do in case.
Thanks everyone for your input.
Enlarge the pasteboard and search Tom Thumb's little rocks!
Has something to do with an object being dragged to close to the edge of the pasteboard between spreads - but it can't be selected/deleted from either.
Best of luck.
Feb 03, 2022 Feb 03, 2022
This is the correct answer. Thank you for helping me with this. The issue I had all along is that there was some item in a table on one of my speads that must have taken up that massive gap between spreads that I couldn't see.
