Suddenly my ADE will not allow mw to download from my library or from Kobo. It tells me that the laptop is not authorised but on checking the unit IS authorised. What I have notice is that where before I had a simple authorization based on my email address, now I have two authorizations ie
EduProd_mfstratico@hotmail.com|Adobe ID and
EduProd_mfstratico@hotmail.com|Copia
Obviously these are spurious address and I would like to deauthorise the laptop and restart from scratch.
Adobe Chat site were supposed to reset the account, but the problem remains. In fact they seem to be a little lost with anything to do with ADE.
How do I clear out the old IDs and start again?
hello
i want try to help you ... if you want to deauthorise your laptop you have to click (in your ade program) on the help button.. then there is a function "delet authorosation " with this function you deauthorise your laptop...
I didn't understand your question completely... but i understood that you want to authorise your laptop to read drm protectet books or to transfer it to your ereader (Kobo?). So i will explain it step by step from the beginning:
1. You need an adobe ID (You have that already i think)
(Don't use special signs in your code word for example äöü or something like that. When I authorised my laptop it didn't work
because of that!)
2. Then download digital editions on your laptop ( I think you did that too)
3. Then click the button "help" and click the first function what means " authorise your laptop"
Then the program says that you should enter your adobe id (that's your e-mail adress) and your password.
Now your laptop is authorised.
If you have a library where you borrow books you have to download the book and when i do that it opens automatically the digital edition program ... Then the book is in the program and you can read it with it on the laptop, or you can trasfer it to your ereader.
For that you connect your ereader with your laptop. After that the programm shows you the reader on the left side. Now you only have to pull the book on the sign of your reader and after that you can read it there
I didn't understand completely what you meant whith the two e-mail adresses... but if you have two adobe ids and if you want to delete one of these accounts you have to write the support team in the chat and they delete one of the accounts.
I hope i was able to help you
Bye
I have no de authorize in that menu and ctrl+shift+D does not help - what is next?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thank you Nanaki your suggestion was very helpful and solved my problem.
Regards
Frank
You are welcome.
Then I also don't know what you can do 😕 perhaps the answer of nanaky helps you ..
