I want to use a Related Topics text Design-Time Control. The
Font options let me set the font name, bold, etc., and underline,
but not the font color. Is there a way to change the font color?
Does it use a style like Expanding Hotspots do? Or can I add
something manually to the code?
If you like, you may make the control hidden. Then you could
make it work by selecting text and making the text a hyperlink. If
you did this, you would have full control over the text appearance.
If that sounds like an approach you would like to take, post
back and I'll flesh out the nitty gritty.
I suppose I could try this. I just can't fathom how the color
is forced to be Blue and there doesn't seem to be any way to change
it. It should be simple. So I'll try anything else.
Thanks!! This worked. I tried it before, but I guess I was
fooled because the text stays blue in the WYSIWYG view. I may have
had it in the wrong spot as well. I was searching all over for a
page that explained these values. Thanks for the link.
