Hi All ,
Thank you for your support ,
Finally i have fix the issue using some changes in my
function in cfc .
<cffunction name="MDArraySort" Returntype="query"
access="public" >
<cfargument name="colArray" type="array"
required="true">
<cfargument name="colNames" type="string"
required="true">
<cfargument name="colSort" type="string"
required="true">
<cfargument name="sensorIDs" type="string"
required="true">
<cfscript>
//Declare variable collection used in function as local
var tmpqry =
Querynew(arguments.colNames,"CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_DATE,CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_VARCHAR,CF_SQL_VARCHAR");
var qRow = QueryAddRow(tmpqry,
Arraylen(arguments.colArray));
</cfscript>
<cfloop from="1" to="#Arraylen(arguments.colArray)#"
index="qRowIndex">
<cfscript>
// Populate the query table
QuerySetCell(tmpqry, 'SENSOR',
colArray[qRowIndex]["SENSOR"], qRowIndex);
'TYPE',arguments.colArray[qRowIndex]["TYPE"], qRowIndex);
QuerySetCell(tmpqry, 'TIMESTAMP2',
LSParseDateTime(arguments.colArray[qRowIndex]["TIMESTAMP2"]),
qRowIndex);
'ORDER_BY_PARAM',arguments.colArray[qRowIndex]["ORDER_BY_PARAM"],
qRowIndex);
QuerySetCell(tmpqry, 'READING_CODE',
colArray[qRowIndex]["READING_CODE"] , qRowIndex);
'READING',arguments.colArray[qRowIndex]["READING"], qRowIndex);
'PK_READING',arguments.colArray[qRowIndex]["PK_READING"],
qRowIndex);
'ALARM_STATUS',arguments.colArray[qRowIndex]["ALARM_STATUS"],
qRowIndex);
QuerySetCell(tmpqry, 'DURATION',
arguments.colArray[qRowIndex]["DURATION"], qRowIndex);
'DESCRIPTION',arguments.colArray[qRowIndex]["DESCRIPTION"],
qRowIndex);
</cfscript>
</cfloop>
<cfquery name="qry" dbtype="query" >
SELECT *
FROM tmpqry
ORDER BY #arguments.colSort# ASC
</cfquery>
<cfreturn qry >
</cffunction>
Rajesh
SCMS
India
