I've Adobe Digital Editions installed in a MacBook Pro and it works perfectly. I can open and read all the files installed. Now, I'm trying to access to the same contents through and Ipad, so I've downloaded the App and I've shared the files through the itunes application. The files are appearing in the IPAd. When I try to open them I get a message to authorize, then I introduce my username and password and it seems to be OK. I come back to the library, double click a book and the same authorization page appears (in this case to ask if I want to deauthorize). The same occurs with any of the books. Please, any idea? What is the problem?
Have you check authorize Digital Edition berfore you try to open a ebook?
How shoud I do it?. Where is that option? I mean, before opening any book, where should I find the option to authorize?
Thanks for your fast answer.
Start Digital Edition on your Ipad without a eBook. In the stettings can add your Adobe ID.
Hi Nanaky, thanks for your answer.
I've tried what you are suggesting, and the result is the same. I even uninstalled Adobe Digital Editions from the iPad, and reinstalled again, then authorize from the settings. But, the result is always the same.
When installing the App, a default book with some explanations about Digital Editions appear and is readable. When I upload a book through the iTunes application, the book appears in the library, with the title, but the cover is blank, and the author unknown. I'm saying that because perhaps could give additional information.
Have you to move the files over the file sytem? (connect the ipad with your mac and tansfer the eBook to the hard disc).
I have authorized before trying to open a book, and the result is the same.
