Duplicate sections throughout TOC after generating multiscreen HTML5 output
Aug 04, 2016 Aug 04, 2016
Using: RoboHelp 10, version 10.0.0.287
Steps to reproduce issue:
1. Click File > Generate > Primary Layout (Multiscreen_HTML5)
2. In Generate window click [Save and Generate]
3. Wait
4. Click [View Results]
5. Results show entire sections of the TOC duplicated in other sections.  Its taking 10 plus times to repeat the generation before all of the TOC items are correct and I can publish.  It's not stopping me from getting the job done, but it's certainly a time killer.
Background: I inherited a working version.  I did not create it.  I have more than basic knowledge of HTML, but I'm not a developer.  I do not have the option to upgrade beyond RH10.  I have researched this multiple times, but have not been able to find any fix.  The only other thing I have seen occasionally are error messages related to toctree.js file, but I don't always get those.  Even when I don't, this still happening, but I have included that error just in case it may be related, although I suspect it is a separate issue.  I don't currently have the corresponding line in the js file because this sample is old and I haven't seen the issue in at least a month.
Other Notes:  I've seen some posts about a similar issue in the printed version but, I am not doing a printed version.  I don't know if that makes any difference, nor do I know if anyone in the past set that up or even where to go to look.
403
Community Expert , Aug 06, 2016 Aug 06, 2016
Try moving the project to somewhere that the path is not so long and generate to a new folder.
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
@petergrainge
Aug 25, 2016 Aug 25, 2016
Thank you so much for your suggestion on this. It worked, and I haven't had one problem since I did this!  My generate time went down from 20-25 minutes to just over 4 minutes, and my attempts to generate went down from 10-12 to 1!  What a HUGE time saver.  Thank you, thank you, THANK YOU! :O)
RoboHelp Documentation
Download Adobe RoboHelp
