SOLVED
Getting error org.apache.sling.servlets.get.impl.DefaultGetServlet No renderer for extension html
Avatar
Level 2
19.08.2015 18:31:19.678 *ERROR* [0:0:0:0:0:0:0:1 [1440009079675] GET /etc/replication/agents.publish.html HTTP/1.1] org.apache.sling.servlets.get.impl.DefaultGetServlet No renderer for extension html, cannot render resource JcrNodeResource, type=cq:Page, superType=null, path=/content/asset-share-portal/en_us/errors
Any of the page is not opening and giving the error DefaultGetServlet 'No renderer for extension html'. Nothing was opening. We checked all content and pages were there..
1 Accepted Solution
Avatar
Correct answer by
Level 2
We finally tried looking into various service settings and found:
It happen due to settings in Apache Sling Resource Resolver Factory settings under Felix configMgr is tampered. We faced this issue and found that the setting for Resource Search Path is missing all entry. Verify the default entry should have following:
/aps
/libs
/apps/foundation/components/primary
/libs/foundation/components/primary
Avatar
Correct answer by
Level 2
/aps
/libs
Avatar
Former Community Member
We have similar problem:
02.05.2016 16:22:29.536 *ERROR* [172.18.138.10 [1462198941448] GET /content/bla/bla/de.html HTTP/1.1] org.apache.sling.servlets.get.impl.DefaultGetServlet No renderer for extension html, cannot render resource JcrNodeResource, type=nt:unstructured, superType=null, path=/content/bla/bla/de/jcr:content/footer/morelinks/link_0_copy
We checked Apache Sling Resource Resolver Factory and found exactly the 4 entries mentioned above in the Resource Search Path.
More recommendations, how to solve this problem?
Avatar
Level 1
@Deleted Account Did you check if your link_0_copy node has sling:resourceType property set?
Avatar
Level 1
I didn't find the solution for this issue but I'm not sure why Rohan's answer was marked as correct when it doesn't resolve the issue.
I went to
http://localhost:4502/system/console/configMgr
and confirmed that the above is already in the Apache Sling Resource Resolver Factory.
Has anyone came across a solution to this issue?
