I have adobe id. I took the option of continuing with authorisation, later had to reset my comp. now im not able to read as it asks me to authorise
You get which error message?
I get authorisation failed.
the message read that this is an authorised id but in order to read the book u need to authorise from that id.
Sent from my Samsung device
No Error which start with E?
There is no such information mentioned like that.
You authoirze Digital Edition?
I have to authorise in order to read the book. I have an authorised id. But it wants me to authorise using the id I first used, I'm not aware of that id as I used the option of no need to authorize
You are used which operating system?
Windows 8
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
