Before I begin my litany of issues, I should mention that I
am using a few of Rick Stone's wonderful hacks as well as some
minor Javascript edits of my own (such as for Breadcrumb style
changes), so I don't necessarily expect everything to work right on
the first try. I am not faulting Rick for any of these issues - he
includes a note at the beginning of his scripts saying that they
are only for IE 6 and may not work in other browsers - but I would
like to get everything to work the same in IE, Safari, and Firefox,
since we are officially supporting all three browsers with our
product. I know, "ask Rick!", right?
But just in case anyone else has already "fixed"
these scripts for Safari and/or Firefox, I figured I'd just ask
everyone.
Internet Explorer 6.0.2900.2180 SP 2
None.
Safari 3.1.1
About box opens with scrollbars. How do I remove them? Where
is the source for the link to the About box so I can insert
"scrollbars=no" into the href?
(SOLVED)
Contents, Index, and Search do not open when they are hidden
using a script from Rick Stone so that the taskbar displays
Contents, Index, and Search instead of using the "Show" link.
(SOLVED)
System opens to table of contents and default topic instead
of default topic only (with panel hidden by the same script).
(SOLVED)
Breadcrumb links underlined at all times regardless of
mouseover status.
(OPEN ISSUE)
Added: Contents, Index, and Search do not function when
hidden and a breadcrumb is used to move away from the current
topic.
(OPEN ISSUE)
Firefox 2.0.0.14
Help window and About box show “file://” in title
bar (running locally). How do I get rid of that? Can I add
something to the href attribute to suppress that?
(SOLVED)
(SOLVED)
(SOLVED)
Breadcrumb links not underlined, even on mouseover.
(OPEN ISSUE)
topic.
(OPEN ISSUE)
Any help would be appreciated.
Chris
P.S. As a former Webworks/ePublisher user, I must admit that
RoboHelp 7 is at least as clean and easy to use if not more so, a
far cry from the last time I used it (when it was still Blue Sky
Software's product!).
