5 Replies Latest reply on Jun 26, 2008 5:26 PM by Newsgroup_User
    PayPal and Contribute
    MelTMC
      A few of my customes are starting to use Contribute to be able to update their own site. I have a site that i set up with Paypal shopping carts and the one thing I can't seem to figure out is how do you edit a paypal shopping cart button that already exist - not built in contribute- with Contribute. Is it possible to change cost and dropdown menus that were built in Dreamweaver in Contribute?
      Mel
        • 1. Re: PayPal and Contribute
          ThinkInk
          Maybe you can start reading the help files of Contribute:
          Editing a PayPal button
          You can edit the setting you originally set for a PayPal button. For example, you might want to raise or reduce the price of an item, update the item name or description, select a different button image and so on.
          To edit a PayPal button:
          1. In the draft, click to select the PayPal button you want to edit.
          2. Select Format > PayPal Properties.
          The highlighted button type for the selected button is the only item enabled in the pop-up menu.
          3. Click a tab in the Advanced options screen to select the type of information you want to update, and then make your changes.
          4. Click OK to save your changes.
          • 2. Re: PayPal and Contribute
            MelTMC Level 1
            I read the help files previously but i can't seem to select the paypal button in the draft. It is wierd...it will put cursor next to button but i can't get it selected. If I look under format button for paypal properties it is not there either. What am I doing wrong?
            Mel
            • 3. Re: PayPal and Contribute
              Level 7
              If the existing paypal button wasn't made with the builtin button generator
              in contribute, it won't be recognized.
              Choices-
              edit the source to change the values using a third party code code editor
              delete the existing button and insert a new one using contribute. That
              button will be editable in the future.
              Alan
              Adobe Community Expert, dreamweaver
              http://www.adobe.com/communities/experts/
              • 4. Re: PayPal and Contribute
                MelTMC Level 1
                What is a good 3rd party code editor?
                • 5. Re: PayPal and Contribute
                  Level 7
                  > Thanks,
                  If you know html, could specify Notepad as the app to edit source code in
                  Contribute 3. Homesite or Homesite+. Any text editor.
                  http://livedocs.adobe.com/contribute/311/using_admin_en/00000084.htm
                  Editing web page source in an external application 3.11
                  Note: If your Contribute administrator has not enabled source editing, ...
                  In the Contribute browser or editor, view the page you want to edit the
                  source ...
                  livedocs.adobe.com/contribute/ 311/using_admin_en/00000084.htm
                  Alan
