Using a Mac with OS X El Capitan 10.11.6 I got problems to authorise my computer. The error message is always "Activation server error - code E_AUTH_BAD_DEVICE_KEY"
The computer was authorised approx. 1 year ago.
What to do to overcome this problem ?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thank you for the advise. However, it did not solve the problem, the message is the same.
The credentials are correct because I could authorise other devices e.g. Tolino e-book reader.
What to do ?
You get the same error message after the remove and authoirze again?
Only by one eBook or when open Digital Edition?
Correct, I get the same error message after removing and trying to authorise again.
This happens when opening Digital Edition and authorising under Help menu as well as authorising trying to open an eBook
Which operating system your used?
Has you emptied trash after remove the activation.dat?
yes, I have emptied the trash and re-started the computer as well
Oddly, it then does not work.
This did not help. Still same error: Activation server error - code E_AUTH_BAD_DEVICE_KEY
