I'm having the same issue as harooki2. Using a bulleted
paragraph style with a custom bullet image (bgbaby.jpg), when I
generate WebHelp there is no space between the bullet points and
the text. The spacing looks fine both in RoboHelp's WYSIWYG editor
and when I output to Printed Documentation (Word doc).
Here are the style sheet parameters I'm using:
p.BulletText {
margin-top: 0pt;
font-family: "Myriad Web Pro", sans-serif;
margin-bottom: 6pt;
list-style: url(bgbaby.jpg);
font-size: 11pt;
margin-left: 0pt;
I've experimented with "margin-left" and "text-indent"
values, and in both cases they move the entire line (bullet
included) rightward rather than inserting space between the bullet
and text. (Margin-left shifts the entire block of text, and
text-indent moves only the top line over).
I see no discernable difference whether "Bullet positioned
inside text" is checked or not in the style's bullets and numbering
options (I have it unchecked at present).
Normal bullets look fine; it's only when using a custom
bullet image that I see this problem. I could use regular bullets,
but I'd prefer to use the custom image as they look nicer.
Any other ideas for inserting some space between the bullet
image and text? (I considered altering the .jpg itself to "widen"
it, adding some blank space on the right side, but I wonder whether
there isn't a better way.)
Thanks..
