As per your request, the HTML code for the example is:
<p>Les agences de services publics peuvent utiliser ce
site pour indiquer
au Centre des armes à feu Canada si elles ont des armes
à feu d’agence
ou des armes à feu protégées à
déclarer conformément au <span style="font-weight:
bold; font-style: italic;"><I><B>Règlement
In the code, the accents appear as the should, however, they
do not display properly.
You are right, problem only occurs on the server, not from
the local drive.
The font we are using is Arial 10pt. We have not tried
different fonts. The only differnce in the three machines was
7.0.2. (two machines had 7.0.2 one had 7.0.1). We are going to test
the projects on a different server.
We did some more testing. Using 7.0.2 and publishing to an
Apache servers causes the French characters to disaply incorrectly.
Using the same project and publishing to a different server (in the
case Unix) no prblems whatsoever. No problems either when we used
7.0.1 and published to an Apacher server.
