1. Re: Error - Unable to import Certificate - You can fix this here
ryanskiheadAug 22, 2016 7:41 PM (in response to matthewp64130044)
App ID?
2. Re: Error - Unable to import Certificate - You can fix this here
matthewp64130044 Aug 23, 2016 10:10 AM (in response to ryanskihead)2226331
3. Re: Error - Unable to import Certificate - You can fix this here
matthewp64130044 Aug 24, 2016 3:04 PM (in response to matthewp64130044)I have again tried to create a new .p12 file as well as a new developer Provisioning Profile and I am still getting the same error:
Is there any support for this? I really need to get this problem solved asap but the only documentation I am finding isn't helpful and none have any answers to any questions.
My developer certificate and profile had expired and I did the exact same process this time but it is not working. I have revoked the old certs and deleted the old provisioning profiles associated with the expired certs. Has anything changed? I noticed the new upgrade caused issues so it has been recommended to revert back cli-5.2.0 in the config file which I have done as well.
Is anyone else having a similar issue? Thanks in advance for any timely support.
4. Re: Error - Unable to import Certificate - You can fix this here
robertf58370139 Aug 25, 2016 5:19 AM (in response to matthewp64130044)Hi
I may be having the same issue: Error - Signing certificate has expired - You can fix this
I haven't looked at the certificate yet to see if it is indeed an issue of the expiration date. Will look at this next...
App id:1293107
5. Re: Error - Unable to import Certificate - You can fix this here
ryanskiheadAug 25, 2016 7:41 AM (in response to matthewp64130044)
This error usually means that the certificate and private key in the p12 file don't match. Have a look at this post, which details more about creating and validating your p12.
Unrelated, and likely that your certificate is indeed expired.
6. Re: Error - Unable to import Certificate - You can fix this here
robertf58370139 Aug 25, 2016 8:42 AM (in response to ryanskihead)Correct, it was exactly that: Certificate has expired. Thx!
7. Re: Error - Unable to import Certificate - You can fix this here
matthewp64130044 Aug 25, 2016 11:50 AM (in response to ryanskihead)Thank you! That post definitely helped and my p12 validation was the issue.
