Not all cell formatting appearing in excel 2013
Aug 26, 2016 Aug 26, 2016
I am using Coldfusion to generate a large spreadsheet (18 tabs) with a lot of formatting and it works perfectly when I view the resulting file in Excel 2010 but a bunch of the formatting is missing in Excel 2013.
If I generate each tab in a separate Workbook then the spreadsheets work great but when combined into a single Workbook, problems appear.
Tab 1 - 3 columns x 19 rows  Formatted 42 cells.  formatting is correct on all cells
Tab 2 - 6 columns x 21 rows. Formatted 92 Cells.  formatting only appears on 42 cells
Tab 3 - 4 columns x 10 rows .Formatted 31 cells.   no formatting appears
Tab 4 through 15.  no formatting appears
Tab 16 - 8 columns x 306 rows. formatting on 37 of 2412 cells
Tab 17 . no formatting appears
Tab 18  4 of 28 cells has formatting.
I was thinking there might be a limit on the number of formats that can be applied to a workbook, but then why would it work in Excel 2010 and not Excel 2013.
I am only using 10 different styles but I am applying them on a cell by cell basis.
Has anyone else run into this problem before?
728
Advocate ,
Aug 30, 2016 Aug 30, 2016
What file name are you saving it as ? xls or xlsx?
Which CF version are you using? I think CF11 is using Apache POI 3.9 which is dated before Excel 2013 as well. Which means it may not support a lot of 2013
I am currently saving the file as xls.  the CF version is 10.0
Advocate ,
Saving as xlsx (Open xml) may give you different results. It uses a slightly different method of producing the file in the back-end.
Saying that. The Apache POI used in CF10 was predating 2013 so will probably cause problems anyway.
They released CF10 update 21 yesterday with security fixes in. One of the things updated is Apache POI. Which means you may get a better chance of resolving the problem.
I would suggest updating you CF10 to the latest update and see if it makes any difference.
Documentation
