Hello, all,
I've got a page where I'm using CFINCLUDE to include another .cfm page that has a list of groups that a user belongs to, and a form field that will allow an admin to add a group to a user's list. It's a select drop-down with an ADD button. The admin should be able to add a group to the user's list without refreshing the page, so I'm using AJaX to submit the data to a cfc; the cfc query runs (successfully adding the group), and returns either a 1 for success, or anything else for a fail.
If a 1 is returned, I'm trying to use jQuery.load() to refresh the data in the div surrounding the CFINCLUDE. But the div becomes empty, and even FireBug is showing that the GET from the .load() is returning nothing.
Some sample pseudo-code:
Parent page (records.cfm):
<div id="rec_adminlist"><cfinclude template="rec_adminlist.cfm" /></div>
<script type="text/javascript">
function reloadDiv(divObj,pg){divObj.load(pg);}
</script>
Child page (rec_adminlist.cfm):
<select id="adminList"> ...</select><input type="button" value="Add" id="submitBtn" />
$('#submitBtn').click(function(){
var $rec_adminlist = $('#rec_adminlist');
$.post("/url/to/cfc/mycfc.cfc?method=addToAdminList",
{adminID: $('#adminList').val(), userID: "#userID#"}
).fail(blah blah blah).always(function(data){
switch(data){
case '1':
reloadDiv($rec_adminlist,'rec_adminlist.cfm');
break;
</script>
The INSERT into the database is successful; but the .load() brings back blank. If I refresh the page, the new data is displayed.
I've never had a problem loading a .cfm page via AJaX, before. Why is this returning blank?
V/r,
^_^
I just replaced the CFINCLUDE with jQuery (on document ready) .load() upon page load, and it's showing a blank, too.
Is it not possible to load a server-side page with jQuery? Could have sworn I did it, before.
V/r,
^_^
Just to make sure I wasn't losing my mind, I used .load() on a txt file, and it worked. So, why not a .cfm file?
V/r,
^_^
What http status does the page have when you call it? You will see it in the dev tools of the browser.
I assume if you call the page normally you see the result you expect after the post?
200 OK 96ms. And yes, if I call the page directly from the browser, it shows up just fine. But calling it with jQuery.load() will display just a blank; even using FireBug to view the HTML shows no code.
V/r,
^_^
There are no variables used inside of the include which are set outside of it? The include is all self contained?
Can you do the following:
divObj.load(pg, function(response, status, xhr){
console.log("Response: " + response);
console.log("Status: " + status);
Post the results of the console.log
There is a variable that is being declared prior to the include. I don't know why no errors were being triggered (nothing visual, no email sent), but the variable was mis-spelled, causing the display to abort (it should have notified me, one way or the other, but didn't.)
It is loading, now.
But why was it giving a 200 response, when the CF was clearly broken? I should have been getting emails out the whazoo indicating what the problem was. I finally discovered what was wrong when I placed the CFTRY/CFCATCH around the whole page instead of just the processing part.
V/r,
^_^
When you are using jQuery Load try getting the status and statusText too. This will tell you if your code is working correctly or giving any error.
$("#rec_adminlist").load("pageurl", function (response, status, xhr) {
if
(status ==
"error"
alert
"Error: "
+ xhr.status +
+ xhr.statusText);
You can also check documentation of - jQuery Load and see the different ways how it can be used to fetch data from other pages.
