Can't erase computer authorization
Aug 29, 2016 Aug 29, 2016
I have been trying to erase an authorization and every time it says I have the wrong password.  I change the adobe password and go back and try again and get the same answer every time.  I went to chat (case # 0219559779) and they couldn't help.  Is there a way to completely erase Adobe edition from my computer including the authorization so I can reinstall with a clean slate?  I have uninstalled the program (4.5) and reinstalled but it keeps showing the authorization.  I've tried regedit but there is no Adet folder to remove.  I'm using Windows 10
804
Aug 30, 2016 Aug 30, 2016
Windows:
    Close all applications.
    Choose Start > Run.
    In the Open text box, type regedit and then press Enter. The Registry Editor opens.
    In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
    Select the Adept key.
    Choose File > Export.
    In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
    Right-click the Adept key and choose Delete.
    In the Confirm Key Delete dialog, click OK.
    Close the Registry Editor.
    Open Adobe Digital Editions and reauthorize.
Macintosh:
    quit Adobe Digital Editions.
    Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thanks for your quick response.
But there is no Adept under Adobe.
HKEY_CURRENT_USER\Software\Adobe has you found?
Aug 31, 2016 Aug 31, 2016
Yes There is an Adobe in hkey_current_user\software\adobe
Thanks again
O.o Are you sure that used the user which are used digital Edition?
Sep 02, 2016 Sep 02, 2016
I am the only user of adobe digital edition
Sep 05, 2016 Sep 05, 2016
Can you make a screenshot and add it in the forum?
Sep 08, 2016 Sep 08, 2016
O. o Strange you sure that start with  HKEY_CURRENT_USER?
Sep 12, 2016 Sep 12, 2016
Yes
then seems digital edtioin not right access to your registry o.O in this point i have no idea was can solved the issue.
Sep 06, 2016 Sep 06, 2016
I have version 10.11.6 The Capitan, but I find the user folder
Ok. thanks for you quick response. I solved it with the information of 10.7 and following
I have this problem in MAC Os
