[moved from Installing, Updating, & Subscribing to Acrobat to Adobe Digital Editions]
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Went through to your instruction, but got the same result.
O.o If you make this the authorize are remove.
When you are remove the key or the file the autorize are remove. So i not sure wat you get for the error.
Sorry, I did not get what you mean. I have already deleted the related registry key, but it did not work. I got the same result as before.
Ali
You are remove the key and Digital Edition still authorize?
Yes. I deleted the key, as per you showed me. But, still not able to erase authorization.
Ali
If you remove the key you can nothing remove because its remove. You should can now authoirze with a other adobe.
O.K. Can you please reset my password?
No. You can this only allone. Go to www.adobe.com -> choose sign in > choose forget password > enter your e-mail-adresse > then you get a mail for password reset.
