VENDOR ERROR CODE 4060 - SQL Server
Sep 05, 2016 Sep 05, 2016
Guys,
We migrate our database from MS SQL 2008 to MS SQL 2012, but, when I tried access our app, the app show me the follows error:
Error Executing Database Query.
Cannot open database "DB" requested by the login. The login failed. ClientConnectionId:562379cb-792a-4d92-88fb-b274aed1a6e9
SQLSTATE       S0001
DATASOURCE       DB
VENDORERRORCODE       4060
We generated a dump from our production environment and we imported into our developing environment, after imported, the CF show for us the error above.
Someone, know how solve this problem?
Tks,
Fabiano Magno Pechibella
Database access
6.2K
Explorer , Sep 06, 2016 Sep 06, 2016
Hi BKBK,
The solution was....
Go to SQL Server >> Security >> Logins and right click on NT AUTHORITY\NETWORK SERVICE and select Properties
In newly opened screen of Login Properties, go to the “User Mapping” tab. Then, on the “User Mapping” tab, select the desired database – especially the database for which this error message is displayed. On the lower screen, check the role db_owner. Click OK.
Tks,
Best Regards,
Advocate ,
It tells you what the problem is. The login failed. There is a problem with your authentication.
You need to start there and make sure all the authentication is setup the same way as it was before the migration.
How did you migrate the SQL? AS this is a Coldfusion forum you may get a better chance asking this somewhere SQL related.
Thanks haxtbh,
I found the problem!
When you generate a dump form other environment and import into in your DB some logins and password are changed,
I don't know why, but this was my problem.
Tks,
Hi Fabiano, good the problem is solved. Please mark the correct answer.
Hi BKBK,
Tks,
Best Regards,
Thanks for sharing that.
Guide ,
Sep 07, 2016 Sep 07, 2016
Is SQL Server running on the same server as ColdFusion?
Might I suggest running the ColdFusion service under a specific Windows local or domain user account, and then add that user to the database logins/users?  That could potentially add a level of security.
Documentation
