Hello !
impossible to change the format to 1280x720 .
when I import a video or a branding video in it , I always have 2 black bars because the format doesn't match the project.
I verified that the option was selected in the preferences before starting my new project.
I tried 4 times and it doesn't work, the exported video is always in the1280x800 format !
Is there anybody knowing that issue ?
Thanks for any help !
Bruno
Hi Bruno,
Video Express has 2 default project resolutions - 1280x720 and 1280x800. If your screen resolution is in the 16:9 aspect ratio, the project resolution is 1280x720. On some Macs, the screen resolution is in the 16:10 aspect ratio. On these Macs, Video Express defaults to a project resolution of 1280x800. This is the cause of the issue you are reporting.
To work around the black bars issue you can import assets that are in the 16:10 format, such as 1280x800. Or you can manually change the
...Copy link to clipboard
Hi Bruno,
To work around the black bars issue you can import assets that are in the 16:10 format, such as 1280x800. Or you can manually change the resolution of your OS to 1280x720. See this link for more info:
How to adjust your Mac display’s resolution settings | Macworld
Please let us know if this helped.
Thank you,
Renzil D'Souza
Video Express Team
