CF11 Enterprise: Double "HTTP 100" Continue causing file uploads to fail
Aug 31, 2016 Aug 31, 2016
For some odd reason, when our users try to upload files to our site running on Cold Fusion 11 through a Big IP F5 set up as a reverse web proxy, the F5 logs are showing a double "HTTP 100 CONTINUE" response which causes the connection to drop.
We are running on a Windows 2008 R2 x64 OS with Cold Fusion 11 Enterprise update 9.
There are 2 clusters one with 5 instances in it which houses the website and a backend single instance that runs our scheduled jobs.
I've tried a whole slew of different things on the OS side and some stuff on the CF side including some connector parameters, none of which has worked at all.
Does anyone have any suggestions?
418
Explorer , Sep 06, 2016 Sep 06, 2016
Ok,
I went into IIS and then into HTTP Response Headers and turned off HTTP keep-alive under "Set common headers" and it looks like i was able to upload a file.  I am having the field do the test now in hopes of them being successful.
Sep 04, 2016 Sep 04, 2016
Try setting the directory where you are trying to upload the files to 775(Apache/Linux) On IIS make sure the directory file permissions are correct.
The permissions are correct and there are no event viewer security logs showing access denial to the folder.
What do the Coldfusion logs show? The issue might have to do with how you integrate Coldfusion and Big IP F5.
I just replicated the issue and checked the logs and there are no log entries within cold fusion what so ever.for the instance that the action was performed on.  The last log entry was from 10 minutes before the action took place.
Also the file I attempted to upload is not in the upload directory at all.
Ok,
Documentation
