I have been trying to erase an authorization and every time it says I have the wrong password. I change the adobe password and go back and try again and get the same answer every time. I went to chat (case # 0219559779) and they couldn't help. Is there a way to completely erase Adobe edition from my computer including the authorization so I can reinstall with a clean slate? I have uninstalled the program (4.5) and reinstalled but it keeps showing the authorization. I've tried regedit but there is no Adet folder to remove. I'm using Windows 10
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thanks for your quick response.
But there is no Adept under Adobe.
HKEY_CURRENT_USER\Software\Adobe has you found?
Yes There is an Adobe in hkey_current_user\software\adobe
Thanks again
O.o Are you sure that used the user which are used digital Edition?
I am the only user of adobe digital edition
Can you make a screenshot and add it in the forum?
O. o Strange you sure that start with HKEY_CURRENT_USER?
Yes
then seems digital edtioin not right access to your registry o.O in this point i have no idea was can solved the issue.
I have version 10.11.6 The Capitan, but I find the user folder
Ok. thanks for you quick response. I solved it with the information of 10.7 and following
I have this problem in MAC Os
