Show 6 replies
1. Re: Align Footnote Numbers
Peter Spier Sep 8, 2016 10:23 AM (in response to n will)Use Lining, rather than proportional, figures, which are all the same width. This won't help, though, when you go from one- to two- to three-digit numbers.
I don't use footnotes enough to remember if the number itself can be set to right-aligned as a numbered list can be.
3. Re: Align Footnote Numbers
Peter Spier Sep 8, 2016 11:44 AM (in response to Obi-wan Kenobi)If the numbers can be right-aligned, you can use the em space, or any other separator.
4. Re: Align Footnote Numbers
Peter Spier Sep 8, 2016 11:44 AM (in response to Peter Spier)And for that matter, you probably could use proportional figures, too.
5. Re: Align Footnote Numbers
Obi-wan Kenobi Sep 8, 2016 12:46 PM (in response to Peter Spier)Aha! Yeap! Totally right! [tired tonight!]
6. Re: Align Footnote Numbers
n will Sep 14, 2016 8:53 AM (in response to Obi-wan Kenobi)Thanks for the help!! Using a tab as the separator worked well. I thought I tried it already, but may have been playing with the indents and spacing options for the paragraph style.
