I have an IMac using OS X Yosemite ver 10.10.5 I can't update Flash Player because it wants a password and I have no idea what it is...HELP
The password has nothing to do with Adobe!
The password is YOUR administrator password on YOUR computer; there is nothing in these forums that will give you the admin password on your machine.
Once you determine this then you should be able to install flash player.
Best Regards
Please be sure to mark my post here helpful or answered if I assisted you
This password prompt is presented by your operating system, and is intended to keep you from accidentally installing software.
If this is your personal machine and you don't need a password to log into the computer when it first starts up, you can probably leave the password blank and click OK to get past this prompt. If this is your personal machine and your normal password isn't working, check to make sure that CAPS LOCK is off, and type the password carefully.
If this is your work machine and it's asking for an Administrator password, well, you'll need to have a conversation with your friendly IT person.
If you're still stumped, you may need to reset the password on your Mac:
http://support.apple.com/kb/PH18653
