Location for SCUP catalog for Adobe AIR
Sorry, We do not deploy update via scup for Adobe Air.
Thank you for the response, how do we update AIR future updates?
Via Background update:
if users have old Adobe AIR, they get a pop-up.
We want to avoid this since all users do not have Admin rights, is there a recommended method to deploy the future updates automatically?
As of now we do not have any silentUpdate mechanism for Adobe AIR update other than the one mentioned above.
We will take your feedback and share with the team.
Ok, please do. Many other companies and Techs are looking for SCUP catalog for AIR. Will be beneficial if it is developed.
Any news on that? We also use SCUP for updating Flash and Acrobat, it would be a great benefit to update AIR and Shockwave the same way.
Regards Sascha
I have been manually building scup data every month for air for years.
# Roger Truss 9-24-2014
# Brunswick Corporation
### most important first step!!!!!!!! ###
Grab the installer from the Download URL: step below and extract the files to get the actual version from the embedded dll.
also get the msi as its needed for app creation in CM12.
7-zip or winrar work well for this.
###### SCUP build info ######
Download URL:
http://airdownload.adobe.com/air/win/download/latest/AdobeAIRInstaller.exe
Save the downloaded exe here:
\\some path\Adobe\Air\current version #
\\some path\Adobe\Air\Scup (overwrite = yes)
##Package Information Section##
Package Source: AdobeAIRInstaller.exe
point to
\\some path\Adobe\Air\scup\AdobeAIRInstaller.exe
Download URL section:
Command Line:
-silent -eulaAccepted
##Required Information Section##
Language:==duh
Title: Adobe Air appropriate version info
Description: autopopulates with title
Classification: Usually Security
Vendor: Adobe Systems, Inc.
Product: Adobe Air
More info URL:http://www.adobe.com/products/air.html
##Installable Rules Section""
(need 2 one for x64 and one for x86 based OSes):
File:
Common Paths: PROGRAM_FILES_COMMONX86
Path: Adobe AIR\Versions\1.0
File Name: Adobe AIR.dll
File must exist and be less than
##Installed Rules Section""
File:
File must exist and must >= the current version
The last 2 sections should have a layout like this and are used in teh app deploymetn ofthe product in CM12:
AND
OR
File '[PROGRAM_FILES_COMMONX86]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version (< for installable rules and >= for installed rules) 'current version'
OR
File '[PROGRAM_FILES_COMMON]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version (< for installable rules and >= for installed rules) 'current version'
Hi Roger,
thank you. I rebuild it but havent test it yet. After first look i thought omg wtf but during building its seems pretty easy - with that type of package .
But i have one/two questions regarding installable rules/installed rules because i cant edit like you have. If i try to add the first "OR" its saying "invalid rule". If i remove it then its good. If i think about it also should work with the first "OR", or? this is what i have eg. inst
AND
File '[PROGRAM_FILES_COMMONX86]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version < '25.0.0.134'
OR
File '[PROGRAM_FILES_COMMON]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version < '25.0.0.134'
failure and "OK" is greyed out
now it would be accepted
if i try to publish it, errors occurs, SCUP.log:
PublishItem: --- Digest verification failed on content for software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85- a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
PublishItem: --- Publish of software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' has FAILED. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
If i activate in "package information" "use a local source to publish..." instead of the mentioned URL "http://airdownload.adobe.com/air/win/download/latest/AdobeAIRInstaller.exe it was succesfully published. Any clue on that?
SCUP.log with URL:
WizardBase: closing Publish Software Updates Wizard wizard. Updates Publisher 17.03.2017 18:00:22 1 (0x0001)
Updates workspace: publish wizard completed. Updates Publisher 17.03.2017 18:00:25 1 (0x0001)
Updates workspace: Starting edit wizard for update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'' Updates Publisher 17.03.2017 18:00:27 1 (0x0001)
WizardBase: closing Edit Software Update Wizard wizard. Updates Publisher 17.03.2017 18:02:28 1 (0x0001)
Updates workspace: edit wizard completed. Updates Publisher 17.03.2017 18:02:31 1 (0x0001)
Updates workspace: Starting publish wizard with 1 updates. Updates Publisher 17.03.2017 18:02:34 1 (0x0001)
Publish: Preparing list of selected updates for publishing. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Connecting to a local update server with locally detected settings. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Publish: Update server name: servername Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Publish: Publish operation starting for 1 updates. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Publish: Publish: Verifying update server is configured with a certificate prior to publishing. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Publish: Publish: Update server appears to be configured with a certificate. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Building dependency graph for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
No dependencies found for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
Found total of 0 dependencies (may include duplicates). Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
PublishItem: Update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'' has no dependencies. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
PublishItem: Publishing update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
PublishItem: --- Evaluating software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' for publishing as FullContent. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
PublishItem: --- Software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' needs to be published with full content. Updates Publisher 17.03.2017 18:02:37 4 (0x0004)
PublishItem: Retrieving content for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
PublishItem: --- Content will be saved to C:\Users\xxx\AppData\Local\Temp\\dguf3hvh.wnh\Adobe AIR Installer.exe. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
PublishItem: Download Content: file was downloaded successfully. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
PublishItem: Successfully retrieved content for software update 'Adobe Air 25.0.0.134 (
UpdateId:'75ddd054- a640-4e85- a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' to local file:
C:\Users\xxx\AppData\Local\Temp\\dguf3hvh.wnh\Adobe AIR Installer.exe Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
PublishProgress: Publish operation completed. Updates Publisher 17.03.2017 18:02:38 4 (0x0004)
Publish: Background processing completed. Updates Publisher 17.03.2017 18:02:38 1 (0x0001)
SCUP.log with local source:
WizardBase: closing Publish Software Updates Wizard wizard. Updates Publisher 17.03.2017 18:03:48 1 (0x0001)
Updates workspace: publish wizard completed. Updates Publisher 17.03.2017 18:03:50 1 (0x0001)
Updates workspace: Starting edit wizard for update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'' Updates Publisher 17.03.2017 18:03:53 1 (0x0001)
WizardBase: closing Edit Software Update Wizard wizard. Updates Publisher 17.03.2017 18:04:09 1 (0x0001)
Updates workspace: edit wizard completed. Updates Publisher 17.03.2017 18:04:12 1 (0x0001)
Updates workspace: Starting publish wizard with 1 updates. Updates Publisher 17.03.2017 18:04:14 1 (0x0001)
Publish: Preparing list of selected updates for publishing. Updates Publisher 17.03.2017 18:04:20 4 (0x0004)
Connecting to a local update server with locally detected settings. Updates Publisher 17.03.2017 18:04:20 4 (0x0004)
Publish: Update server name: servername Updates Publisher 17.03.2017 18:04:20 4 (0x0004)
Publish: Publish operation starting for 1 updates. Updates Publisher 17.03.2017 18:04:20 4 (0x0004)
Publish: Publish: Verifying update server is configured with a certificate prior to publishing. Updates Publisher 17.03.2017 18:04:20 4 (0x0004)
Publish: Publish: Update server appears to be configured with a certificate. Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
Building dependency graph for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
No dependencies found for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
Found total of 0 dependencies (may include duplicates). Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: Update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'' has no dependencies. Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: Publishing update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'. Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: --- Evaluating software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' for publishing as Automatic. Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: --- Software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' needs to be published (no content). Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: --- Metadata only SDP XML file for publishing created at C:\Users\xxx\AppData\Local\Temp\tmpB3E.tmp Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: ---Using default return codes for update... Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: --- Calling update server API for publishing update 'Adobe Air 25.0.0.134 (UpdateId:'
75ddd054-a640-4e85- a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:04:21 4 (0x0004)
PublishItem: --- PublishPackage call successful for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' Updates Publisher 17.03.2017 18:04:22 4 (0x0004)
PublishProgress: Publish operation completed. Updates Publisher 17.03.2017 18:04:22 4 (0x0004)
Publish: Background processing completed. Updates Publisher 17.03.2017 18:04:22 1 (0x0001)
WizardBase: closing Publish Software Updates Wizard wizard. Updates Publisher 17.03.2017 18:04:25 1 (0x0001)
Updates workspace: publish wizard completed. Updates Publisher 17.03.2017 18:04:28 1 (0x0001)
Thank you. Published it anyway and lets wait for SCCM recognition how much devices will need it
So sorry for the super long delay, looks like notifications for this chain I am not getting. The first OR was a typo, sorry about that. As to the publication error that is because the source file you used was not the same as what was on the web.
