1. Re: remove white space infront of text in text frame
SJRiegel Sep 15, 2016 12:07 PM (in response to megank59940857)1 person found this helpfulCan you post a screen shot to illustrate your problem?
Unless your text box has insets specified, the longest line of the centered text will be at the edge of the text frame.
2. Re: remove white space infront of text in text frame
Haeme Ulrich Sep 16, 2016 7:51 AM (in response to megank59940857)1 person found this helpfulDo you have an intent in the text frame options (select the text frame > object > text frame options). If not you could make the text frame smaller with a double click to the handle of the text frame on the left or the right side.
best
Haeme Ulrich
3. Re: remove white space infront of text in text frame
didiermazier Sep 16, 2016 8:59 AM (in response to megank59940857)You could use negative indents for your paragraphs
4. Re: remove white space infront of text in text frame
megank59940857 Sep 16, 2016 11:38 AM (in response to SJRiegel)Thank you for taking the time to help!
You are correct, the longest lines do touch the edge of the text frame. I suppose my question is how to remove the white space from the beginning of a given line of text. I've seen some people manipulate it in a way that can even cause it to hang out of the text box. As an example: In this frame, I would like to remove the space from before the word "She", so that it starts directly on the edge of the text frame.
5. Re: remove white space infront of text in text frame
SJRiegel Sep 16, 2016 11:43 AM (in response to megank59940857)What you are asking is inconsistent with also centering the text.
To have the left side of the text touch the edge of the frame, set it to align left.
6. Re: remove white space infront of text in text frame
jane-e Sep 16, 2016 5:30 PM (in response to megank59940857)
