quote:
Originally posted by:
Linux Rules
Assuming you do not have in-line expanding text that you
WANT, you can search-and-replace to change the in-line expanding
text to a drop down text in the generated files.
Change (replace) the following:
<a class=glossterm
...with...
<a class=dropspot
...and...
x-popup-type=expanding
...with...
x-popup-type=pulldown
GEWB
Thanks for this bit of info...
Seems like the code changed a bit for RoboHelp 7? The
generated WebHelp output looks like this in the HTML source:
<a class="glossterm" href="javascript:TextPopup(this)"
id="HotSpot11681">Glossary Term</a> <span
class="glosstext" style="display:'none';"
id="POPUP11681">Glossary Definition</span>
The
class="glossterm" is there and can be changed in the HTML,
but there is no
x-popup-type=expanding anywhere in the generated HTML.
However, it is in the referenced ehlpdhtm.js file. When I looked at
.js file, I found the code where this is all defined (won't post it
on the forum because I'm not sure if that's ok).
Basically, it looks like I will have to write my own code
(and have RoboHelp not reference it's own javascript when
generating a hotspot) if I want to customize this to operate how I
want it to operate.
