10 Replies Latest reply on Oct 16, 2017 2:32 AM by arenol
    Unable to print from Adobe. Says no pages selected
    scottg35963594 Level 1
      All of sudden I can no longer print PDF documents.  Keeps on saying "there were no pages selected".  I have uninstalled adobe and reinstalled, restarted the computer, etc
        • 1. Re: Unable to print from Adobe. Says no pages selected
          abhissha Adobe Employee (Admin)
          Hi Scott,
          May I know the application that you are using to Print the PDF file. Also please mention printer make and model.
          Please try the following:
          Solution 1:
          Open the PDF file in Acrobat/Reader.
          Choose File > Print.
          Click Advanced button in the Print dialog box.
          In the resulting Advanced Print Setup dialog box, select Print As Image and click OK.
          Solution 2:
          Close Acrobat/Reader.
          Choose Start > Run and type %APPDATA%\Adobe\Acrobat\ in the Open text box. Click OK.
          Right-click the version folder (for example: 11.0 or DC) and choose Delete.
          Start Acrobat/Reader and print.
          Note: Acrobat preference files contain application settings such as toolbar arrangements. Once Acrobat is restarted, new preferences will be created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
          Solution 3:
          To see if there are multiple documents stuck in the printer queue and delete them:
          Click Start > Devices & Printers
          Double-click the printer you are attempting to print to.
          If there are documents in the queue, choose File > Cancel All Documents. It maybe necessary to restart your computer after choosing this option.
          Solution 4:
          Go to Edit > Preferences
          Under categories click on Security (Enhanced)
          Try temporarily turning off Protected View (Acrobat)
          Uncheck Enable Protected Mode at startup (Reader)
          Solution 5:
          Under categories click on Documents
          From PDF/A View Mode drop down on the right select 'Never'
          Click Ok. Restart Acrobat/Reader and print.
          Let me know if this works.
          Abhishek
          • 2. Re: Unable to print from Adobe. Says no pages selected
            hallb99775916
            I also am suddenly unable to print any PDF files, including ones I have previously printed. It is not a printer issue since I can print other file types to different printers with no problems. The computer is using 64 bit Windows 7. Initially I was using the latest version of Adobe Acrobat Reader DC. I uninstalled that using the uninstall process of Windows 7. I tried to down load a new copy of Acrobat Reader DC but it was an unsuccessful install. I then down loaded from Adobe Acrobat 10. That exhibits the same problem of "no page selected". When I call for a print and get the printer page the 'button' for ALL is not grayed out but the buttons for Current Page and Pages are grayed out. These are NOT grayed out when calling for a print for other type files such as DOCx, DOC, XLSx, etc. and they print just fine. I have moved some PDF files to my wife's computer and they print just fine. I have used Windows System Restore to back up one level of Windows updates and that has not provided any fix.
            The ability to print PDF files is a MUST HAVE feature and I am becoming VERY FRUSTRATED that none of the suggestions I have found, including those you offered to Scott work.
            PLEASE help me to resolve this issue.
            Thank you very much for any assistance you or others can provide to resolve this issue
            • 3. Re: Unable to print from Adobe. Says no pages selected
              hallb99775916 Level 1
              Things are now working. I opened Help, went to repair instillation. That did not fix the problem. I then went to Check for updates. It came back that no updates are available but opening a previously unprintable PDF file now prints. This has only occupied about 6 hours of my time including several of lost sleep in the process. Not a happy camper about that but at least I can once again print PDF files. Perhaps my floundering approach may help someone else.
              • 4. Re: Unable to print from Adobe. Says no pages selected
                I have a Brother MFC printer.  None of the suggestions work.  I have had to download another PDF reader and I now have PDF printing.  Thank you for your time.
                1 person found this helpful
                • 5. Re: Unable to print from Adobe. Says no pages selected
                  Hi Scott,
                  I apologize for the inconvenience caused. I would like to know whether printer drivers are updated. Also was this working for you earlier?
                  Please check on Brother's website for the latest PS drivers for your machine.
                  Abhishek
                  • 6. Re: Unable to print from Adobe. Says no pages selected
                    Hi,  Yes my Brother machine has been updated.  That was my first port of call.  And yes the printing had been working fine for about 4 months, since I got this new computer. And with my old computer the printing never missed a beat.
                    • 7. Re: Unable to print from Adobe. Says no pages selected
                      stevenh62337944 Level 1
                      There is a workaround (perhaps only for Windows, IDK) that worked for me, the only solution that I could follow the steps and, voila, print.
                      To wit:
                      If you are dealing with this error message, and you are using Acrobat or Reader on Windows, there is a simple workaround. This is not a fix, and does come at a price, but at least it will allow you to print:
                      Open up Acrobat’s (or Reader’s) preferences (Edit>Preferences or Edit>Preferences>General), then select the “Security (Enhanced)” category.
                      Now deselect the setting “Enable Protected Mode at Startup” and restart the application.
                      If this does not work, try to set “Protected View” to “Off”.
                      This information is from khkonsulting.com/2014/10/pages-selected-print-error/
                      BTW, this thread that has gone on for years without Adobe having interest in helping and/or passing the buck to someone else ... yeah, I really don't think much of the company.
                      • 8. Re: Unable to print from Adobe. Says no pages selected
                        thomasb80000000
                        The last solution worked for me, this rocks!
                        • 9. Re: Unable to print from Adobe. Says no pages selected
                          vmavma
                          That suggestion did not work. It still prevents me from printing any document with the same error.
                          The easiest solution is to right-click on the file, then "open with" Microsoft Word. It nicely opens though it may not be the exact same way adobe would display it. Then print. Microsoft word reliably prints it.
                          • 10. Re: Unable to print from Adobe. Says no pages selected
                            arenol Level 1
                            Had the same problem, and found the culprit - I believe.
                            When I opened a PDF that is an image, and tried to print it with "Print as Image" selected, I got the error above.
                            When I deselected "Print as Image" it would print as expected...
                            Agnar
