I have just installed Production premium suite and keep getting this type of error for 6 of the components:
----------- Payload: AdobeColorCommonSetRGB CS6 4.0.0.0 {C7B1C1B3-368D-4C32-A818-83F1554EB398} -----------
ERROR: DF024: Unable to preserve original file at "/Library/ColorSync/Profiles/Profiles" (Seq 11)
How do I get around this so these components work: After effects, Photoshop, Illustrator, Flash Professional to work for CS6
Please see the KB Doc for troubleshoot with install logs : Troubleshoot with install logs | CS5, CS5.5, CS6, CC
This URL does not exist! Still having trouble.
Hannanefc I have updated the URL in message #1. The document can also be found at Troubleshoot with install logs | CS5, CS5.5, CS6, CC.
This link leads to nothing helpful.
The answer from Josh Ulm did not help either.
the error on my side is :
ERROR: DF024: Unable to preserve original file at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/AdobeCrashReporter" (Seq 94)
That`s why the renaming of profiles ... does not work
I solved this by going into the mentioned folder, /Library/ColorSync/Profiles/Profiles and renaming that folder. Then retry. The installer will create a new Prolfiles folder and be able to complete the installation. Afterwards you can delete the old folder.
Not sure why, maybe a permissions issue, or a corrupt file. Anyway, it works.
for me, I have an error saying ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{3FB7A108-368A-4849-A3F3-69571BAAC457}\_1_b9e4689359fdc59da875efece27e6487
to "C:\Program Files (x86)\Common Files\Adobe\Adobe Photoshop CC 2015\32 bit Photoshop dlls\libifcoremd.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 1)
Crisg63506027 Error DF024 installing Adobe Creative Cloud, Creative Suite, Elements products was recently created to provide additional guidance on how to resolve this error. If you have any questions regarding the steps listed in this document you are welcome to update this discussion.
if you get ERROR: DF024 then you will have to Verify file permissions
