1
Open JSON file and parse it? (ExtendScript)
Contributor ,
Sep 19, 2016 Sep 19, 2016
I know that JSON isn't built into ExtendScript but even with the downloaded lib I do not understand how you are supposed to use this?
If I try and use #include in my jsx-file the entire script comes to a halt (nothing gets loaded)
main.jsx
#include "../js/libs/json2.js"
alert("this does not trigger! - script halted on line above");
So what's the approach here? Send the file path from JS to JSX, create a file object and read every line in JSX, returing the file string back to JS and then parse it?
Actions and scripting
20.6K
Contributor , Sep 20, 2016 Sep 20, 2016
Summary
-The JSON -library json2.js can be "included" in the main.js file by running evalFile(pathToFile). I assume this also works in JSX. Thanks goes to Davide Barranca for showing us the way!
-You cannot use #include in the JSX file for Photoshop as this will completely break the execution
-When reading the file, you have to do it all in one go - not line-by-line (see below).
I read the JSON-file incorrectly, which broke JSON.parse()
For some reason I had setup the function that did the reading, t
Adobe
Advocate ,
I understand that you're referring to an HTML Panel context, am I correct?
If this is the case, yes, include will not work. You have to send the extension's path down to the JSX from the JS, then evaluate json2.js with $.evalFile().
From that point onwards, the JSON object should be available to your extendscript context.
Davide Barranca
Contributor ,
I moved the parsing to the JS file instead but it appears that you can't even use JSON there! JSON is undefined -_-
Why did Adobe make things so bloody complicated?
EDIT
I put the JSON.parse() inside a try-catch and I'm getting syntax errors (which is weird as I've used several online validators on my JSON code)
Exception:SyntaxError: Unexpected token :
JSON
    "lolk": [
            "icon": "/img/picA.png",
            "path": "/scripts/file.a",
            "text": "somethingA"
            "icon": "/img/picB.png",
            "path": "/scripts/file.b",
            "text": "somethingB"
            "icon": "/img/picC.png",
            "path": "/scripts/file.c",
            "text": "somethingC"
EDIT2
JSON.parse() seems to be completely broken?
try{
    var lol = JSON.parse("{'lolk':'stuff'}"); // Exception:SyntaxError: Unexpected token '
    alert(lol);
} catch(e) {
    alert("Exception:" + e + "\nCould not run JSON.parse()");
If you want to parse JSON in extendscript, you can use a polyfill. Here's an easy example you can copy/paste: generator-gizmo/rootscript.jsx at master · codearoni/generator-gizmo · GitHub
Just paste that at the top of you extendscript file and you should be good to go.
Contributor ,
Summary
For some reason I had setup the function that did the reading, to read the file row-by-row, like this:
JSX
    file = new File(filePath);
    file.open("r", "TEXT");
    var fileString = "";
    while (!file.eof){
        var line = file.readln();
        if (fileString.indexOf(line) == -1){
            fileString += line;
    return fileString;
Which seems to add characters that the parser does not like.
I changed it so that it just reads the entire file
JSX
    var scriptFile = File(filePath);
    scriptFile.open('r');
    var content = scriptFile.read();
    scriptFile.close();
