I'm using a background update server to upgrade our network computers (Windows 7 X64) from Flash Player 16 to 23.
Everything works fine, client are updated fine except that FlashPlayerUpdateService.exe file is deleted after upgrade, same for the service who call this file, and for the automatic task that call the service...
Here is my mms.cfg :
SilentAutoUpdateEnable=1
AutoUpdateDisable=0
SilentAutoUpdateServerDomain=NameOfMyServerMasked
SilentAutoUpdateVerboseLogging=1
And here is the install log :
=O====== M/23.0.0.162 2016-09-20+08-50-21.398 ========
0000 00000044
0001 00000045
0002 00000010 FlashPlayerInstaller.exe -install -iv 9
0003
0004 00000011 1
0005 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0006
0007
0008
0009
0010
0011 00000013
0012 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_23_0_0_162_ActiveX.exe
0013 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_23_0_0_162_ActiveX.dll
0014 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
0015 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0016 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017
=X====== M/23.0.0.162 2016-09-20+08-50-27.635 ========
If I install the update manually with the msi everything works fine, and the update service still here...
Thanks for your help.
Hi
We could not reproduce this issue, could you try uninstalling on one system and reproduce this.
And send us exact steps to reproduce this.
Ok, here are the steps I'm doing to reproduce it :
=O====== M/16.0.0.305 2016-09-20+12-38-03.396 ========
0000 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\InstallAX_16_0_0_305.exe" -install -msi
0001
0002
0003 00000011 1
0004 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013
0007 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe
0008 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll
0009 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
0010 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00000012
=X====== M/16.0.0.305 2016-09-20+12-38-06.516 ========
2016-9-20+12-53-54.100 [info] 1628 srvsus01.hopital-saint-joseph.fr
2016-9-20+12-53-54.100 [info] 1629 srvsus01.hopital-saint-joseph.fr
2016-9-20+12-53-54.101 [info] 1614
2016-9-20+12-53-54.101 [info] 1615
2016-9-20+12-53-54.101 [info] 1618
2016-9-20+12-53-54.102 [info] 1619 1063
2016-9-20+12-53-54.119 [info] 1628 srvsus01.hopital-saint-joseph.fr
2016-9-20+12-53-54.120 [info] 1629 srvsus01.hopital-saint-joseph.fr
2016-9-20+12-53-54.120 [info] 1614
2016-9-20+12-53-54.120 [info] 1615
2016-9-20+12-53-54.120 [info] 1618
2016-9-20+12-53-54.121 [info] 1604
2016-9-20+12-53-54.121 [info] 1608
2016-9-20+12-53-54.126 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
2016-9-20+12-53-54.242 [info] 1630 /pub/flashplayer/update/current/sau/22/xml/version.xml
2016-9-20+12-53-54.243 [info] 1632
2016-9-20+12-53-54.244 [info] 1630 /pub/flashplayer/update/current/sau/22/xml/patch.xml
2016-9-20+12-53-54.245 [warning] 1445
2016-9-20+12-53-54.245 [info] 1632
2016-9-20+12-53-54.245 [info] 1600
2016-9-20+12-53-55.192 [info] 1602
2016-9-20+12-53-55.192 [info] 1609
2016-9-20+12-53-55.192 [info] 1612
2016-9-20+12-53-55.193 [info] 1620
=O====== M/16.0.0.305 2016-09-20+12-53-56.780 ========
0000 00000010 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe -uninstall activex -msi
0001
0002
0003 00000018
0004
0005
0006 00000018
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027 00000011 1
0028 00000012
=X====== M/16.0.0.305 2016-09-20+12-53-57.383 ========
=O====== M/23.0.0.162 2016-09-20+12-53-55.435 ========
0000 00000044
0001 00000045
0003
0004 00000011 1
0006
0007
0008
0009
0010
0011 00000013
0017
=X====== M/23.0.0.162 2016-09-20+12-54-01.711 ========
Thank you for posting the log files. This is due to permissions errors on the file system and/or registry. The error is in the last line of the log file:
0017
1031 is the Flash Player error code when there are permissions issues on a file. The number 5 is the ERROR_ACCESS_DENIED Microsoft error code. Due to incorrect file system and/or registry permissions the file can't be created, which results in the Background Update Service Task and Service not being created.
The Troubleshoot Flash Player install issues related to Windows registry permissions help doc has information on fixing this, as does the FAQ How do I fix Windows permission problems with Flash Player? The script posted here is very restrictive to Flash Player files, however, it's possible another file, indirectly used by Flash Player installer, is the cause. If running this script doesn't work, you can try running this script from Microsoft, available at https://support.microsoft.com/en-us/kb/968003, which resets permissions on all files/registry entries in the system
Hi m_vargas,
I understand that it's a permissions problem, but the fix you asked to apply doesn't fix the problem.
I've tried with others versions of Flash player, it's always the same behavior the flash player works fine, but during background update the FlashPlayerUpdateService.exe seems to be in use and cannot be update by the process.
Same for Update task that is deleted but not created again.
=O====== M/16.0.0.305 2017-01-30+09-04-03.866 ========
0001
0002
0003 00000018
0004
0005
0006 00000018
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027 00000011 1
0028 00000012
=X====== M/16.0.0.305 2017-01-30+09-04-05.442 ========
=O====== M/24.0.0.194 2017-01-30+09-04-01.074 ========
0000 00000044
0001 00000045
0002
0003 00000010 FlashPlayerInstaller.exe -install -iv 9
0004
0005 00000011 1
0006 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0007
0008
0009
0010
0011
0012 00000013
0013 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.exe
0014 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.dll
0015 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
0016 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
0017 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0018
=X====== M/24.0.0.194 2017-01-30+09-04-09.545 ========
Hi Boris, to help us resolve this issue please perform the following troubleshooting steps and share the results with us:
1. Create a Process Monitor log file:
You can download Process Monitor from: https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx.
Run Process Monitor and remove any default filters. Then reproduce the issue, waiting until the FlashPlayerUpdaterService.exe file is deleted. Then send us the Process Monitor log file.
2. Install the old Flash Player using an EXE installer instead of an MSI installer, then try to reproduce the issue. You can find old Flash Player EXE installers at Archived Adobe Flash Player versions.
3. Disable any running antivirus programs, then try to reproduce the issue.
4. Launch a command prompt "As administrator" and run the commands below, then try to reproduce the issue.
net start PcaSvc
net start AeLookupSvc
John
