Unable to link ADE with Overdrive
Guest
Sep 19, 2016 Sep 19, 2016
When I download a book from my library using Overdrive it shows up in Overdrive bookshelf,not ADE. I have reinstalled ADE several times.It is aurhorized OK.When I initially log into ADE,I put in Adobe vendor ID as 'Overdrive' from list.Is this correct?
Every thing used to work OK for several years till I had to replace hard drive and reinstall everything.I have spent hours trying.Help would be much appreciated.
Thanks.
716
Community Beginner , Sep 21, 2016 Sep 21, 2016
command prompt brings a DOS window. On windows10 you do a right click in
the left corner of the bottom task bar. You will find it where the restart,
power, shutdown options are. I'm not a vendor. I have been using ADE for
many years and consider it a very unfriendly product. The libraries should
find an alternative for distributing books. Every time I get a book from
the library I feel lucky when I don't have to go through additional
juggling.
On Wed, Sep 21, 2016 at 12:06 AM, davidm16257369 <forums_
Sep 20, 2016 Sep 20, 2016
If you used as vendor ID used Overdrice its says not that download the File automatic. You must open the eBook manuell over the filesystem to digital Edition.
Remove ade from your PC.
Go into documents and remove 'my digital editions' folder
Go into command prompt
type regedit
Find the adobe section
delete the adept Folder
reinstall ADE
Open your ACSM overdrive book
It will then ask you to login with adobe user & PW
the book should then open
Guest
Thanks for that reply Howardy
I am not sure of where is 'command prompt'.
And also, when I reinstall ADE and I have to put in Adobe vendor id,then my
user name & pw,do I select Overdrive from drop-down list for vendor id.
Thanks Dave
On 20 September 2016 at 21:16, howardy81730007 <forums_noreply@adobe.com>
juggling.
On Wed, Sep 21, 2016 at 12:06 AM, davidm16257369 <forums_noreply@adobe.com>
