security error accessing url
Avatar
Former Community Member
I'm using flex builder to create a small flex project to
learn how to
call web service in flex,but I encountered a problem really
confusing
me.I created a new file called wstest.mxml and here's its
content:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="vertical">
<mx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.rpc.Fault;
import mx.rpc.events.FaultEvent;
private function onFault(event :
FaultEvent) : void
var f : Fault = event.fault;
Alert.show
(f.faultString,"Error");
private function list() : void
adminService.getWeather.send();
</mx:Script>
<mx:WebService id="adminService" service="Weather"
port="WeatherSoap"
wsdl="
http://www.wopos.com/webservice/weather.asmx?
wsdl" showBusyCursor="true"
fault="onFault(event)">
<mx:operation name="getWeather">
<mx:request>
<mCity>
ÉϺ£
</mCity>
</mx:request>
</mx:operation>
</mx:WebService>
<mx:Label id="lbl"
text="{adminService.getWeather.lastResult}"/>
<mx:Button label="Call Web Service" click="list()"/>
</mx:Application>
After building finished,I ran the generated wstest.swf in the
directory called bin,the output directory of the flex
project,everything is ok.But when I put the swf file in
another
position, say, c:/. Then when I ran the swf file an error
message was
returned saying 'Security error accessing url'. I can't
understand
why this happened. It seems the swf file can only run under
the bin
directory. Any one can help? Thanks!
Avatar
Level 1
I have 2 projects stored in the SAME file system location,
SAME project/folder structure and calling the SAME webapp/webpage.
One of them works, the other gets "Security error accessing url".
I even copied the entire mxml page content from the working
project to the none-working, and vise versa. That one project just
keeps giving that error.
Is there a project property I need to set?
I don't have crossdomain.xml in my webapp, but not sure that
I need it because clearly one of the project run fine without it.
Thanks.
Avatar
Level 1
I hope, you should keep useProxy="false" in WebService tag.
it might works for you.
