Just changed the email address for my Adobe Digital Editions en had it verified. Nevertheless when I use the 'new' Adobe ID it says 'you can only authorise your computer with an Adobe ID that hasn't been used for the authorisation of a computer or a mobile device. Try again.'
So the question is 'how can I get an Adobe ID that wil work.......'
Thanks in advance,
Wil
you can send me an email at [email removed -- no personal info allowed on forum]
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thank you very much for your advice. I'll apply it one of these days and will inform you about the result!
Wil
Good Luck.
