13 Replies Latest reply on Apr 29, 2018 4:50 AM by fabrizione
    wacom tablet jittery with graphic's processing enabled
    JSP8475
      Hi all,
      I've had the wacom intuos pro for some time and mainly do photo editing
      I use liquify a lot and if I have the graphics processing enabled my pen tip gets quite jittery and the tablet become quite useless.
      I did some googling and went to services to restart the wacom tablet driver but no luck
      the only solution I could find is to disable graphic's processing on photoshop
      Using Windows 10 and GTX750Ti
      graphic's driver version is 364.51 according to nvidia control panel
      Wacom driver is 6.3.15-3
      Does anyone have any tip to resolving the issue other than to disabling graphic's processing support?
        • 1. Re: wacom tablet jittery with graphic's processing enabled
          Trevor.Dennis Adobe Community Professional
          Are you using WinTab or Windows Ink?
          • 2. Re: wacom tablet jittery with graphic's processing enabled
            If Windows Ink is disabled
            Create a file that contains instructions to revert to the WinTab functionality.
            Create a text file in a text editor such as Notepad.
            Type in the following lines:
            # Use WinTab
            UseSystemStylus 0
            Save the file as a plain text file named PSUserConfig.txt
            Put (copy) the file into the Photoshop settings folder: C:\Users\[User Name]\AppData\Roaming\Adobe\Adobe Photoshop CC 2015\Adobe Photoshop CC 2015 Settings\
            Restart Photoshop and check the pen pressure and overall performance.
            2 people found this helpful
            • 3. Re: wacom tablet jittery with graphic's processing enabled
              JSP8475 Level 1
              hi, Trevor
              Big Thanks first!
              I've turned off Windows Ink by un-checking the check box (highlighted in green rect.) on your screenshot
              It has alleviated the symptom tremendously but still feel jittery in liquify with the graphics support on.
              Not sure if the unchecking the checkbox does the same thing or not, but copying the txt file in "Adobe Photoshop CC 2015 Settings" folder has helped further smooth the operation....
              still a ted bit jittery but a huge advance compared to previous performance
              Thanks again!
              • 4. Re: wacom tablet jittery with graphic's processing enabled
                Since it sounds like you are using Windows, do you have Lazy Nezumi Pro installed?  Now I am not sure if it will help with this or not.  I've talked to Guillaume about jittery pen movement and Lazy Nezumi Pro, and I have a feeling he said it wouldn't help in that respect, but it is worth a try.  I am of the opinion that no tablet is complete without LNP as well, and it keeps getting better.  There is also the complication that with some operations LNP is more of a hindrance than a help.  The Crop tool for instance, is impossible to use with LNP turned on.
                Give it a try.  You get 30 days trial, and it costs $35 to buy.  I LOVE it, but my gut feeling is that it won't fix your problem.
                Since this GPU related, have you tried using different GPU settings rather than turning it off completely?  Set Drawing mode to Basic, or turn off use OpenCL.  You need to restart Photoshop after each change for them to take effect.
                It's a common problem — including it being especially bad with Liquify — and I have heard of people fixing it by rolling back the Wacom driver.
                I also suspect that Wacom issues are often related to crosstalk with other pointer devices, like mice and touchpads.  What are you using?  Setpoint, for instance, I've heard of causing problems with Wacom devices.  If you are using it and have a non setpoint mouse you can use, then try removing it.
                What tablet are you using and is it wireless?  Try using a cable.  Do you have a cordless phone on the computer desk?
                Is the problem consistent?  If not can you correlate the problem to other factors?
                Good luck, and let us know how you get on.
                • 5. Re: wacom tablet jittery with graphic's processing enabled
                  JSP8475 Level 1
                  Thanks Trevor for more reply
                  I'm using Wacom Intuos Pro medium
                  Since your post about Windows Ink, I thought everything was OK
                  but then when I looked more close to the settings I noticed the pressure wasn't registering during the liquify at all (stylus pressure check box was greyed out)
                  reinstalled the driver and the pressure was back on
                  but the jittery performance was back again
                  now I'm thinking this is more of a Wacom hardware problem....
                  or maybe some sort of driver screw up (it's a rather slim chance that this is the case since I clean reinstalled the windows on my 128gb ssd and all the drivers)
                  • 6. Re: wacom tablet jittery with graphic's processing enabled
                    JSP8475 Level 1
                    Hello, Trevor
                    From my last post I've called Wacom first and have told them of the symptom
                    They've told me that everything should be running smooth and asked me to send a video via e-mail
                    I've tested on my MacBook Pro (15" highest with external Nvidia graphics latest Yosemite and CC and Driver) as well and the jittery cursor was barely noticeable but was there as well
                    I went to Wacom service center in my city (Seoul, South Korea) and the staffs were rather baffled by the symptom
                    I've tested my tablet on their computer (running windows 7 and photoshop CS5) and the cursor was running smooth in liquify even with graphics support enabled.
                    They've never seen any behavior like this before and heard no report yet
                    I've tested their tablet on display ( actual working display model for customers walking in to play with while the their products are being repaired ) on my MacBook pro
                    and the cursor was jittery as well
                    so they're going to try out with Windows10 and Photoshop CC on their own PCs to see if it's occurring on Windows10+PsCC
                    and then contact Wacom Japan on Monday to see if this is a known case and that if there's a solution to it.
                    Their diagnose was that this is a result of some sort of driver/program/OS mess up since my tablet was running fine on their computer.
                    If this is indeed software related, they told me it's going to be a long wait until new driver or software update from Wacom and Adobe would roll out since it'd require more than Wacom to come up with a fix.
                    I'll post update as I get news from Wacom Korea
                    • 7. Re: wacom tablet jittery with graphic's processing enabled
                      JSP8475 Level 1
                      edit
                      From my last post -> Since my last post
                      • 8. Re: wacom tablet jittery with graphic's processing enabled
                        JSP8475 Level 1
                        I've received the test model from Wacom Korea and the results were the same
                        now hardware is definitely not causing the problem, at least not the tablet...
                        the issue was occurring both my work desktop and personal desktop and I've only tested on work desktop so....
                        I'm gonna tinker with the test model a bit more and visit Wacom Korea on Thursday (GMT+9)
                        • 9. Re: wacom tablet jittery with graphic's processing enabled
                          JSP8475 Level 1
                          Just before I left work, I installed driver on my co-worker's PC (i5 with AMD graphics HD...6 thousand something, windows10) and it was flawless with/without graphics support on PsCC settings
                          I returned home from work and have tested with a laptop(lenovo E320 with i5 and switcheable graphics between intel and AMD, win7), desktop(i3 with intel graphics, win10) and MBPr15" late 2013 with latest Yosemite update
                          MBPr does show a bit of jittery once in a while but it's not too bad compared to the desktop (i3)
                          lenovo laptop showed flawless performance with both external and internal graphics...
                          desktop was OK but on both (graphics support on/off) occasions the cursor would jump opposite to the direction of my stroke time to time...
                          test model's the same
                          I took video of each test with my phone and will be presenting the case to the Wacom Korea on Thursday..
                          • 10. Re: wacom tablet jittery with graphic's processing enabled
                            Henrik L. Hjort Level 1
                            Trevors fix worked for me. But it apparently is importnat how you save the file. So you have to make it in notepad and then File > SaveAs... Otherwise it will not work.
                            Also I didn't need to disable "use windows ink".
                            I'm running. Win 10, PS 15.5
                            • 12. Re: wacom tablet jittery with graphic's processing enabled
                              DeZnas Level 1
                              Thanks Trevor, the txt file did the trick
                              • 13. Re: wacom tablet jittery with graphic's processing enabled
                                fabrizione
                                Thank you, I'm having the some problem but the txt saved me!
                                Just pay attention, notepad save ita as "PSUserConfig.txt.txt" and obviously it doesn't work this way, check it and change the name.
