I would like to use the Programm for HTML 5 and PDF without FlashPlayer. Is that possible???
Maren
No that is not possible. When you publish to PDF it embeds the Flash version of the presentation in the PDF.
HTML versions of the presentations are only available as stand alone output from Presenter.
That means, that my customer using my elearnings must use flash?
No, you can publish your presenations as HTML.
However, if you publish them as a PDF, then they will be Flash based.
I tried to puplish as html, this is the result: http://arbeitssicherheit.download/presenter/Test/index.htm
It appears you are having the issue with Presenter 11 and PPT 16. Please reach out to the Adobe staff member on this thread and he will help with a resolution, Problem with HTML5 output Presenter 11 and PPT 16
This may also be causing the issue with you publishing to PDF, it may be worth asking about it at the same time.
Thank you, do you mean it works with ppt 2013?
I tried it with ppt 2010. HTML5 publishing was possible, but answering the quiz don´t work.
No PDF file could be created
