Insanity: doing the same thing over and over again and
expecting different results.
Albert Einstein
I explained the purpose of this file in your previous post
here.
Go back and read my last reply there. If you don't want to do that,
I'll repeat here: the whtdhtml.htm is for FORMATTING ISSUES ONLY
(setFont, setIcon, stuff like that)!
As Peter says, the output TOC will not include a new topic
until you manually add it to the source TOC.
In addition, the way to update the output is to LET ROBOHELP
DO IT! Create the Layout and select your Generate and Publish
options (Generate to a folder on your local machine and Publish to
a server location; once you've published the first time, RH will
only publish the new and changed files from the previous Publish).
As to the whdata, whgdata, and whxdata folders (your other
concern from the previous post), RH balances its TOC, Index, and
Glossary info among a series of numbered files, for better download
performance. For example, as the whxdata\whtdata13.xml reaches a
certain size, RH stops using it and creates whxdata\whtdata14.xml
for a certain amount of new entries. It might also do some further
balancing of all previously generated files, and you can never
predict what will change and what will not. As I said at the top,
just Generate WebHelp and let RH do everything.
Resistance is futile...
