While attempting to do Find operations with ExtendScript, FM2015, I find that the documented constants for FS_FindCustomizationFlags do not resolve. From the doc:
Constant.FS_FindCustomizationFlags (15) - An optional parameter of type FT_Integer that may be any of the following bit flags OR’ed together:
• Constants.FF_FIND_CONSIDER_CASE (0x01)
• Constants.FF_FIND_WHOLE_WORD (0x02)
• Constants.FF_FIND_USE_WILDCARDS (0x04)
• Constants.FF_FIND_BACKWARDS (0x08)
For example, this just reports "undefined":
alert(Constants.FF_FIND_CONSIDER_CASE);
I worked around it by specifying the hex integer directly, but I'm wondering if I'm just missing something. And FWIW, I originally bumped into this looking for a way to search with regular expressions. I found this in the FDK fapidefs.h file, which fortunately allowed me to get it to work:
#define FF_FIND_USE_REGEX | ((IntT) 0x10) |
Russ
Hi Russ,
this bug has been fixed with update 3 (Ref# 4102169).
But I don't know if FM 10, 11 or 12 is affected.
Klaus
Hi Russ,
Klaus
Hi Klaus,
Good catch, thank you. I haven't had a chance to install the update yet but I do see the information in the release notes.
Russ
