Here is a code _placeOrder.java generated using wsdl2java.exe
utility:
* _PlaceOrder.java
* This file was auto-generated from WSDL
* by the Apache Axis WSDL2Java emitter.
package com.domain.services;
public class _PlaceOrder implements java.io.Serializable {
private com.domain.services._PlaceOrder_orderData orderData;
public _PlaceOrder() {
public com.domain.services._PlaceOrder_orderData
getOrderData() {
return orderData;
public void
setOrderData(com.domain.services._PlaceOrder_orderData orderData) {
this.orderData = orderData;
private java.lang.Object __equalsCalc = null;
public synchronized boolean equals(java.lang.Object obj) {
if (!(obj instanceof _PlaceOrder)) return false;
_PlaceOrder other = (_PlaceOrder) obj;
if (obj == null) return false;
if (this == obj) return true;
if (__equalsCalc != null) {
return (__equalsCalc == obj);
__equalsCalc = obj;
boolean _equals;
_equals = true &&
((this.orderData==null &&
other.getOrderData()==null) ||
(this.orderData!=null &&
this.orderData.equals(other.getOrderData())));
return _equals;
private boolean __hashCodeCalc = false;
public synchronized int hashCode() {
if (__hashCodeCalc) {
return 0;
__hashCodeCalc = true;
int _hashCode = 1;
if (getOrderData() != null) {
_hashCode += getOrderData().hashCode();
return _hashCode;
// Type metadata
private static org.apache.axis.description.TypeDesc typeDesc
new org.apache.axis.description.TypeDesc(_PlaceOrder.class);
static {
typeDesc.setXmlType(new javax.xml.namespace.QName("
http://services.domain.com/",
">PlaceOrder"));
org.apache.axis.description.ElementDesc elemField = new
org.apache.axis.description.ElementDesc();
elemField.setFieldName("orderData");
elemField.setXmlName(new javax.xml.namespace.QName("
"orderData"));
elemField.setXmlType(new javax.xml.namespace.QName("
">PlaceOrder>orderData"));
elemField.setMinOccurs(0);
typeDesc.addFieldDesc(elemField);
* Return type metadata object
public static org.apache.axis.description.TypeDesc
getTypeDesc() {
return typeDesc;
* Get Custom Serializer
public static org.apache.axis.encoding.Serializer
getSerializer(
java.lang.String mechType,
java.lang.Class _javaType,
javax.xml.namespace.QName _xmlType) {
return
new org.apache.axis.encoding.ser.BeanSerializer(
_javaType, _xmlType, typeDesc);
* Get Custom Deserializer
public static org.apache.axis.encoding.Deserializer
getDeserializer(
return
new org.apache.axis.encoding.ser.BeanDeserializer(
