I created an adobe ID and later I realized I misspelled my email though the registration was successful. And now I can't erase the authorization so that I can use adobe ID with correct email since I forgot the password and it's not possible get new one. Though I contacted customer care and they were able to correct the email.
Thank you for your help. I'm using windows 10, I followed the instructions and I found inside Adept there are two folders. I found the Key inside Device folder. After deleting the Key still the authorization was there. Then I google and found the instruction to delete Activation folder (http://feedback.datalogics.com/knowledgebase/articles/843867-removing-the-adobe-digital-edition-authorization-w) also found inside Adept. And now everything is fine
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Thank you for your help. I'm using windows 10, I followed the instructions and I found inside Adept there are two folders. I found the Key inside Device folder. After deleting the Key still the authorization was there. Then I google and found the instruction to delete Activation folder (http://feedback.datalogics.com/knowledgebase/articles/843867-removing-the-adobe-digital-edition-auth...) also found inside Adept. And now everything is fine
You are welcome.
