I started a trial of RH in order to evaluate its ability to generate JavaHelp[/OracleHelp] output. From the online documentation and from the Adobe tutorial I watched I was led to believe that there were generators for both of JavaHelp and OracleHelp. However, I don't see these output types as being available. Am I missing something?
Can anyone help with this? TIA.
Note: I have seen some vague references in the forum to JavaHelp no longer being supported, but I can't see any definitive documentation on this.
Note2: I have a large Java application that I'd like to integrate RH generated output into and I'd like this to be pure Java (having to use Web Help or HTML help and manually triggering a browser to run is a non-starter).
Hi there
While it's not specific to those odd output formats, see if the video below helps you sort making them available.
Cheers... Rick
Hi there
Cheers... Rick
Hi Rick,
Yes, thank you, this is what I needed in order to add both the JavaHelp and OracleHelp output format generators. Thank you.
I was able to fully generate the OracleHelp JAR file (once I found the OracleHelp download on Oracles Java download site ), but not the JavaHelp JAR file due to RH's inability to locate a JavaHelp "install directory". I'm not sure what that is since I've been unable to find a JavaHelp 2.0 "install" file to "install". I have the JavaHelp 2.0 JAR file but this seems insufficient for the RH JavaHelp generator. Any ideas on this one?
Thx!
Sadly, nope. Those output formats are a bit foreign to most RoboHelp users.
Maybe another forum user will see this thread and offer some insight.
Cheers... Rick
Thx Rick (and Peter), this is helpful, yes.
Unfortunately the main item I'm looking for here is the JavaHelp 2.0 install download (and the link for this in Peter's page is broken ). Obviously Oracle appears to be hiding this pretty well (or they've completed purged it from their site). Oddly, I can't seem to find any other location that provides this download. I'm not averse to going with OracleHelp, but I do have a slight preference for JavaHelp (unless someone can convince me otherwise ).
Given that neither of these forms of help have been supported for years, I
am curious as to why you want to cling on. Is there a reason you cannot use
Webhelp or an HTML5 responsive output?
My understanding is that OracleHelp is actively developed/supported http://www.oracle.com/technetwork/developer-tools/help/utilsoft-ohw-422139.html.
Both JavaHelp and OracleHelp allow for an integrated help system within a pure Java application. This is in contrast to WebHelp or HTML5/CSS output, which must be viewed in a "browser". Note: there are embedded browser Java technologies (e.g., JXBrowser) that provide a pure Java browser capability where these types of help output could be viewed, but this is an added complication that's not required when integrating JavaHelp/OracleHelp directly.
I'd be fine with going with OracleHelp if JavaHelp is indeed dead/no longer supported (although it's interesting to me that this is still supported as an output generation type in RH 2015).
BTW, this requirement isn't unlike other large Java applications - e.g., the NetBeans Java IDE uses JavaHelp as a basis for its application help framework.
