Locked
6
Manually installing PDF Printer
Guest
Oct 04, 2012 Oct 04, 2012
My name is Justin and i work for Desktop support for a company. Im currently having a issue with installing  a PDF printer, we install Adobe Writer 9 Pro through the network using advertised programs on Win XP. Whenever i install the application it does not seem to automatically install a PDF printer on my pritner list. When i attempt to manually add it i get through all the steps sucessfully, however upon clicking finish, it then opens a directory box which wants me to point it somewhere, when i click cancel it then says something about inserting disk. Where i work discs are dissallowed, can anyone tell me where it wants me to point it or any potential workaround that i would not have to specify a path? My assumption is that it wants something from system 32 or adobe's program files but it does not specify.
Install update and subscribe to Acrobat
1.6M
correct answers 2 Correct answers
Adobe Employee , Oct 04, 2012 Oct 04, 2012
Please note that the Adobe PDF Printer functionality to create PDF files  is only available with Adobe Acrobat (paid version), and not with Adobe Reader (free version).
Solution 1
Repair the Acrobat installation using the option in the Help menu.
Solution 2
Uninstall and then re-install Acrobat on your Windows OS.
Solution 3
Manually install the PDF Printer
  • Click Start >  Control Panel > Devices and Printers
  • Select Add a printer
  • Select Add a local printer
  • Check Use an existing port and select Documents\*.
Adobe Employee , Jul 09, 2019 Jul 09, 2019
You may take help from the following updated Adobe article Adobe PDF printer is missing | Manually install PDF printer
Anand Sri.
Adobe Employee ,
Solution 1
Solution 2
Solution 3
  • Check Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down.  Click Next
  • Click the Have Disk… button
  • Click the Browse… button
  • Navigate to C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Xtras\AdobePDF
  • Select AdobePDF.inf from the list, then click the OK button
  • You will see many Adobe PDF Converters in the list, however count six down from the top and click Next (you may need to try this numerous times to find the correct Converter from the list that works with your version of Windows)
  • Name your printer, e.g. Adobe PDF
  • Follow the rest of the prompts and your PDF printer should now be installed correctly
If you are later prompted for the ADPDF9.PPD file, it can be found in the C:\Program Files\Adobe\Acrobat 10.0\Acrobat\Xtras\AdobePDF\<OS version> folders.
Guide ,
Oct 26, 2012 Oct 26, 2012
Thank you very much for that, Rave -- especially the manual install procedure. Very helpful.
Jan 07, 2013 Jan 07, 2013
Hi Rave ~~
I also am having problems with my PDF Printer. It worked fine for years, then a few months ago it disappeared from the printer list and now I can't print to PDF. I tried your Solution 3, Mannually Install PDF Printer, as described above but my file structure for Acrobat 6.0 doesn't look like what you described for Acrobat 10.0.
In Step 4, after checking 'Use an existing port', there is no 'Documents\*.pdf' to select from the drop down.
In Step 7, there is no path on my c drive called C:\Program Files\Adobe\Acrobat 6.0\Acrobat\Xtras
I searched my entire harddrive and backup drive for a file named, AdobePDF.inf. There isn't one on there.
Can you send me the installation procedure that will work with Acrobat 6.0? I would be so grateful. I am unable to use Solution 1 or 2 as my source disk is packed in one of a garage full of boxes.
I am using a Dell XPS running Windows XP SP3. I usually use FireFox 17.0.1 browser, but occasionally use IE 8.0.6001.
All updates are current.
Nov 12, 2014 Nov 12, 2014
You should be able to open Acrobat and go to Help>Detect and Repair. For updates you will have to access them from ftp://ftp.adobe.com/pub/adobe/acrobat/.
Engaged ,
Aug 14, 2013 Aug 14, 2013
How does this change for Version 11?
Note: I don't particularly want Adobe *.pdf to end up in
\Desktop or
\Documents
so can I just type in a directory of my own choosing?
Thanks.
Just check in the properties of the Adobe PDF printer and you can check to always ask where to create the PDF.
Can you please help me install adobe as a printer for windows 8. I have adobe 11.1. Thanks
My guess is you have Reader 11.1, not Acrobat. If you have Acrobat 11.0.09 the printer should automatically be installed. Reader does not include the print driver, the latter simply being a PS printer driver. To get PDFs you also need Distiller that is part of the Acrobat release.
May 05, 2016 May 05, 2016
Please! I need to know how do it ( Manual install ) on Mac! ( El Captain )
I need " Print as Adobe PDF" in my preferences in Illustrator and photoshop but my Virtual Adobe Print are missing
I reinstall Acrobat DC but Adobe PDF virtual print don't install!
Oct 19, 2016 Oct 19, 2016
I have same problem in macOS Sierra (10.12.1). When install Acrobat DC, the "Adobe PDF" printer don't install on my mac preferences. I need them for make a booklet build on Indesign. (work with .ps and distyler after is very boring).
Have any way to install PDF Printer manually?
Adobe Employee ,
Hi TitoMatheus,
It is not possible as Adobe PDF printer is not available on Mac anymore. Please refer this link to create Adobe PDF on Mac: Can't print PDF files on Mac OS X 10.6 to OS X 10.8
Meenakshi
May 25, 2017 May 25, 2017
I'm having an issue installing the pdf printer driver on my computer. I tried the multiple things that are stated above and nothing has worked. It seems when I did the windows update my printer spool stooped working, so I had to uninstall and re-install all the printer drivers. I have adobe cs6 and when I go to print settings, the print to pdf driver would appear, now it does not. Any help would be much appreciated.
-Al
Nov 11, 2021 Nov 11, 2021
Hi!
I am having the exact same issue with the Adobe printer. I have Adobe Acrobat DC Pro installed, but Adobe PDF does not show up as a printer option. I've tried:
1. To correct/fix the installation,
2. Reinstall Adobe (multiple times)
3. And also try to manually add the printer by using the steps above.
all resulted in no luck. What else can be done so that Adobe PDF can be installed as a printer? Please help!!
Dec 30, 2021 Dec 30, 2021
Having the same problem.
Tried to Repair Installation and manual install, no luck...
Windows 10, Lenovo ThinkPad
Jan 20, 2015 Jan 20, 2015
I have tried to install as a printer and these are not options that I have. I am using Adobe Reader XI, Windows 7, Firefox
When I follow this step: Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down.  Click Next
this is not an option that I have.
If I manually try to: Navigate to C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Xtras\AdobePDF
This is not an option that I have either.
What I am trying to do is save a gmail as a PDF. From all my searches online it looks like I can do it if I can install PDF as a printer but I don't see a way to do this. Is there a way?
Thanks, Joe
Feb 05, 2015 Feb 05, 2015
Joe - Did you ever get help on this? I just recently downloaded the free trial for Acrobat Adobe Reader X1 and the PDF printer did not automatically install to my printers and I can't figure out to add it. Please let me know if you figured it out
Adobe Employee ,
Hey Jhmaidan,
As suggested By Rave, Adobe PDF Printer functionality to create PDF files is only available with Adobe Acrobat (paid version), and not with Adobe Reader (free version).
Rahul
Jul 22, 2015 Jul 22, 2015
Do you have Acrobat installed? The printer is part of Acrobat and Acrobat is required to install the printer.
Mar 24, 2015 Mar 24, 2015
Using Windows 7 Pro 64 bit trying to save as pdf using print option. Pay for ability to create them but shouldn't need the subscription to do so.
"Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down.  Click Next" --- Doesn't exist
"Navigate to C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Xtras\AdobePDF" --- Doesn't exist
Any help greatly appreciated
May 07, 2015 May 07, 2015
I though that as well, but each slash / is a new file to open, First:Program Files (x86), then click open: Adobe then click open: Acrobat 10.0\ and so on, you will find each step works accordingly.
May 11, 2015 May 11, 2015
I am using Windows 8.1.
When I get to this:
"Check Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down.  Click Next"
There is no Adobe option to select.  How should I proceed?
Participant ,
Sep 21, 2015 Sep 21, 2015
Same here.  I have a new Windows 8 machine and cannot get files to print to PDF no matter what I try.
None of the above thread works.
This worked to a tee thank you!
Jan 14, 2016 Jan 14, 2016
Thank-you.  It worked like a charm, I have Adobe Acrobat 11 / Windows 8 and it was the first driver on the list.
